lorryz
Hi all,
Firstly, I've read through most of the gearbox woes threads on the forum. I think I might have sheared a selector fork (FML if this is the case). But not a 100% sure as my case seem a little different.
Hoping to get some feedback/advice.
For context - I drive an 02 BAM S3 8l, and I have a dieselgeek sigma 6 short shiftier fitted. + I've been meaning to do a gearbox realignment as I feel 1st and 2nd getting a bit sloppy as of late.
- I took the car out today and about 40 minutes into my drive I pull up at a set of lights.
- Go into 1st and feel almost a crunch, plus its stiff and off where it normally is located.
- Pull it out of 1st, put it back in, Still feels weird (located). Go around the corner, stop, Go into neutral and I then try to drive again. And i cant find 1st.
- After a couple of goes, I eventually find 2nd. Then proceed to nurse the car home (leaving it in 2nd and clutching in at lights).
- Once home, I try to find Neutral and get 3rd.
- Now the car only has 3rd and 4th. No Neutral and No 1,2,5 or 6th gears. or Reverse
- Clutch still works and i can move the car in 3rd (not that i want to), but I no horizontal movement in the gear leaver. So I can only go from 3rd to 4th (under duress).
So, I'm hoping its a failure in the linkage/short-shiftier, but it all looks to be in the right place.
And the fact i have No horizontal movement, leads me to think its more detrimental.
However, I find it weird that I lost all but 2 gears ( couldn't imagine i sheared all the selector forks ? )
Any help would be greatly appreciated, before I start throwing time and money at it.
Laurence
Laurence
