no mate... conventional method risks damage to the master cylinder which is a 200 quid part from Audi...
Tbh you will get a better result with the Eezi Bleed... make sure you don't use more than about 18psi and test the seal on the master cylinder before putting fluid in the bottle by pressuring up empty...
Its easy to use but worth getting a mate to help keep an eye on the fluid level else you may need to cycle the ABS pump too...
Start from the rear doing the passenger side first the then drivers side... move to the front again passenger side first and drivers side then do the master cylinder nipples last... be careful with the MC nipples as they are fragile and prone to snapping
