340mm front and 310mm rear last time I checked.
check your pr codes when looking for bits so you don’t get the wrong ones.
If you look on the sticker in your boot or service book there will be a list of codes like 1JK, 1BC. Each one relates to something fitted to your car from factory.
when looking at likes of euro and other parts selling places they will have these codes.View attachment 264183
My go to has always been trw. They generally come with all the fittings, bolts, sensors to do the job. been using them for years on all other cars and never had any issues.Thanks mate , didn’t even know about the boot sticker . See you use AUTODOC . Same place I’ve been looking.
Considering going for Zimmerman discs and pads , any experience of them ?
For 10+ years, I've been using Zimmerman with no issues. On my MK1 TT and 8P A3, i combined the Zimmermans with Akebono Euro ceramic pads. Almost no brake dust and disc corrosion is minimized too. Ate Ceramic is my second choice.Thanks mate , didn’t even know about the boot sticker . See you use AUTODOC . Same place I’ve been looking.
Been stung once since brexit. It was about £400 worth of parts so £100 in chargers including courier charges. Think you get away with smaller amounts.Been looking at autodoc do you always get custom charges?
Are the oem brake discs trw and the oem pads ate?
The trw pads are better priced
Sent from my SM-S901B using Tapatalk
Only one of fronts had sensor and rears no sensor if I remember right.Another question I should have asked is do rear pads also have wear sensors or just the fronts. Fl model if it makes any difference
Thank youOnly one of fronts had sensor and rears no sensor if I remember right.
I wouldn't recommend these for the S3 or performance car. My dad has them on his Q2 and they're fine for a normal car. I had them on my S3 but they generate more heat (dependent on how you drive too), warped my discs and had a permanent blue tinge to the disc indicating heat damage. Braking performance/feel was a bit meh too, didn't fill me with confidence.Ate Ceramic is my second choice.
