hi, i have owned an a3 1.8t quattro for 5 years now and was faultless, i decided to buy an s3 8l at the beginning of the year , since buying it has developed 3 issues
1. there is a rotational grinding/rubbing noise when driving from what seams to be the n/s/f , this started off happening when lifting off the gas and coasting, but now has changed to when driving at constant speed and stops when accelerating or lifting off the gas , i have jacked up the front and spun both wheels an nothing can be heard and cannot see any spots where rubbing is taking place.
2. after the car is up to temp there is white smoke from the exhaust and a smell of burning oil. I'm guessing turbo oil seals unless anybody has any other suggestions?
3. idle when bad, found pipes on either side of valve under inlet manifold had come away from valve so replaced with genuine new unit which fixed idle, but now when turbo is boosting the boost just cuts out and there is a pop sound at the rear exhaust box, the only thing i did notice when fitting the pcv pipework that the rubber hose from the y piece to the pcv valve has been contaminated with oil and has collapsed
(this image is not mine but one i found on google images)
any help would be apprenticed
