- Joined
- Dec 17, 2006
- Messages
- 1,969
- Reaction score
- 687
- Points
- 113
S3 8P fans running all the time, even with no key in the ignition!.
So this afternoon, I decided to check out the gear cable end links on my S3 with a view to fit the 42DD VAG Shifter Bushing Set as sold by AKS.
So I removed my Revo intake and unplugged the connector going to the temperature sensor in the coolant pipe above the gearbox for a better view.
However, when starting the engine after putting everything back together both fans came on full blast. Turn off the ignition and they still kept on running. I undid the negative battery terminal and they stopped.
I then just turned the key to ignition without the engine running and they started up again.
Seemingly, the only way to stop them was to disconnect the battery.
So what is going on and what is the fix? I am thinking a dodgy temperature sensor that I disturbed by unplugging the connector.
Please help!!
Please help!!
