Hey,
Few days ago in the middle of driving my clutch started coming up really slow, about 2 seconds till its in normal position. So i went to mechanic he bleed the clutch but no use. The fluid it self was dilluted. Next day he swaped slave cylinder and new fluid, bleed it but it was no use still same so next he did replace master cylinder and we still in same situation.
All gears work fine but i felt some sliping before the pedal started coming up slow mostly in high rpm or higher gear with load. While he did the slave cylinder we inspected preassure plate and clutch disk they were pretty worn and DMF had some play.
So the question is what else can cause slow return for clutch pedal. Would it help if i change DMF and clutch kit whitch i plan to do anyway or is there no way a worn clutch set could affect the pedal so it would return slowly.
Mileage is 143k km. 2008 model. Any suggestions is appreciated!
