  2. Dismiss Notice
S3 2011 POOR HANDLING
rhysdavies91 Jun 21, 2017
  1. rhysdavies91
    rhysdavies91 Registered User
    59
    13
    Hi all soo my s3 is poor at handling the back end wants to slide out when i go around a corner reasonably fast,
    and doesnt really feel safe going 80mph+ anyone else have this problem? what is the best course to improve it??? any advice let me know
    thanks
  2. Avatar
    snack-media
    Advertisement
  3. Moxy89
    Moxy89 Registered User
    376
    161
    43
    That's not right at all.
    What tyres are you running
    Has it been crashed ?
    The s3 is known to under steer, but it certainly should feel planted at high speed,
    Change the arbs, anti lift kit and coilovers will massively improve the handling
    S. and DJ_26 like this.
  4. T8DPR
    T8DPR Guest
    when you're at 80+mph, are you slowing for roundabouts?
    S. and Tylerrr. like this.
  5. Moxy89
    376
    161
    43
    Think he means even going straight... 80+ on a roundabout is going to make most people's bum hole twitch
  6. rhysdavies91
    59
    13
    haha iv got mid range tyres on in. and no it hasnt been in a crash, i was thinking of getting coilovers on it as iv been had a car where you feel like your going to lose grip around a corner doing over 65ish and it wasnt that sharp at all cant really explain it plus its 4 wheel drive so it should handle better surly..
    ill order and coilovers and upgrade the bushes maybe?
    thanks anyway
  7. T8DPR
    T8DPR Guest
    how are your tyre pressures... also have a look at your current tyres and see if there's any uneven wear that doesn't point to incorrect tyre pressures, it could then point to something else
  8. rhysdavies91
    59
    13
    no the tyres are all pretty brand new by the looks of things and cant see any wear on them just confusing really
  9. kash_v
    kash_v Registered User
    362
    77
    The back end caught me out in Mexico once, fast into a round about - Rear stepped out unexpectedly (I caught it). Had new tyres too/pressures fine/alignment fine.
    They really need uprated anti roll bars to help with the additional weight of the haldex system IMO.
  10. rhysdavies91
    59
    13
    plus iv heard the standard shock are **** on them
  11. kash_v
    362
    77
    That all depends on your mileage.
    Go look at the size of your arbs, you'll see what I mean
  12. Avatar
    snack-media
    Advertisement
  13. nluk100
    nluk100 Registered User
    1,554
    326
    What tyres are you using? Sizes? What pressures are you using?
  14. Essflee
    Essflee Registered User
    2,157
    70
    Could be worth getting a four wheel alignment too unless you wanted to spend the cash on all new suspension.
  15. S3Alex
    S3Alex Rarely neutral Gold Supporter
    10,887
    4,883
    My feeling was that the stock car understeers like a pig.
    Needs good tyres(Michelin Supersports etc)
    Coilovers.....I've tried kWv3 and Clubsports,and now runs a Bilstein B16 kit,with 235x20 rims
    ARBs
    ALK etc
    It takes a lot of effort to get rid of the thing's tendency to go straight on through corners.
    kash_v likes this.
  16. SootySport
    SootySport Registered User
    4,200
    1,130
    Check the Haldex is working and the 4 wd is actually Clicking in when it should.
    S3Alex likes this.
  17. DJ_26
    DJ_26 Registered User
    491
    192
    43
    I would say check that the 4WD system is working as it should. Then maybe look at tyres, tyre pressures and then wheel alignment, followed by your springs, shocks and and anti-roll bar.
  18. Marek196c
    Marek196c Gilera Runner / A3 Sportback
    826
    111
    43
    As DJ_26 said I would start of checking all bushes, anti-roll bar, wheel alignment...
