s3 1.8t 20v into VW Golf MK3 injector issues
hrb93 Oct 13, 2018
  1. hrb93
    hrb93 New Member
    13
    Hi all,
    I have installed a 1.8t s3 AMK into a mk3 Golf.
    Using the standard 1.8t ECU with the immobilizer deactivated and the SAI/N80 and N249 removed.
    The injectors are not firing. It cranks, checked voltage and depending on when you test (just turned ignition on etc) they have voltage of 3.5v.
    The injectors and fuel spray (direct from a battery) and all good. Unable to check the oscillation of the negative which fires them.
    The plugs have spark.
    any ideas?
    Thanks.
  2. Avatar
    Google AdSense Advertisement
  3. hrb93
    hrb93 New Member
    13
    problem solved.
    first start all good.
    project finished.
  4. nightroamer
    nightroamer Member
    96
    13
    What was the problem in the end?
    Chuck up some pictures of the project
    Sent from my iPhone using Tapatalk Pro
