  2. Dismiss Notice
S-line Mudflaps
Simonrich Mar 30, 2014
  1. Simonrich
    Simonrich New Member
    25
    Despite everyone saying it's not possible I decided to see for myself so I bought a set of front and rear mud flaps from my dealer.
    Just fitted rears today and took a few hours, to be honest they almost fit anyway but half an hour with a dremel to reshape the contour made them follow the lower part of s-line bumper much better. Ignore fitting instructions in the box as they sit a bit lower than the instructions suggest and just drilled two new holes to the inside lip of the wheel arch liners, needed a couple of longer bolts too but otherwise straightforward.
    Will try to upload some photos in a bit.
    Next weekend will try fronts, a quick look suggests more modification of the flaps will be neded.
    andy203 and jimladallen like this.
  2. Avatar
    snack-media
    Advertisement
  3. andy203
    andy203 Q5 Black Edition
    292
    62
    Nice one Simon, have been trying to work out what I was going to do on this front. Want mudflaps for the muddy country roads here in winter. Will await with interest as others will I'm sure.:icon_thumright:
  4. cuke2u
    cuke2u Well-Known Member
    12,823
    5,222
    Can you post up some pictures of the process and how they fit please...
  5. Simonrich
    25
    best I can do with photos
    andy203 likes this.
  6. andy203
    292
    62
  7. cuke2u
    12,823
    5,222
    Thanks for the photos, they look a bit chunky..
  8. Simonrich
    25
    Hi Andy, you need a couple of 2 inch bolts to fit the main side attachments, plenty of room behind so not exact, with locking washers or I used nylocks, the mud flaps fit about an inch lower than the instructions because s-line bumper is deeper than SE, so I also used a couple of metal supports at the inside edges of mud flap, 99p from pound shop.
    Contour of flap needs adjusting slightly at its lower edge SE bumper curves in in one contour, s-line is straighter then tucks in at it's bottom, you need to adjust flap to copy this but it's no big job, I used a Dremel and it took 30 mins to do both.
    Side fittings are lower therefore just drill 2 holes and use new bolts, you are drilling through week arch liner and plastic bumper support behind, easy to drill through, new bolts then fit sides. Original bolt supplied fits up under side into bumper once hole drilled and use plastic fitting supplied with flaps. As inside edges of flap are lower use metal support and original bolts from kit to fix to wheel arch liner to make to rigid, finished job is very solid.
    andy203 likes this.
  9. andy203
    292
    62
    Thanks for that Simon, will wait to see the fronts when you get round to doing them.
  10. Simonrich
    25
    Andy
    Photo of support bracket
    Terry simons likes this.
  11. Simonrich
    25
    Just fitted front flaps following quite a bit of modification, the side skirt does not just stick further out to the side it is also deeper and further underneath the car so the flap has to be cut away to fit. Also as it overlaps the wing and side skirt you have to cut into the flap, this results in a L shaped hole through the flap, I filled this with some heavy duty polystyrene foam cut/glued/sealed into place. All the supplied fittings were used as per the instructions.
  12. Avatar
    snack-media
    Advertisement
  13. Simonrich
    25
  14. andy203
    292
    62
    Will be interesting to see how much protection these give to spray etc up the side of the car. You will have to go and drive down some mud covered roads.
  15. Daz Auto
    Daz Auto Active Member
    660
    201
    43
    Hi Simon,
    Attached is a copy of the photo I sent to the dealer. They told me it didn't fit our SE because it was a mud flap for a 3 door car. It looks very similar to the s-line contour in your photos.
    Edit: comparing the photos closer, I would say the kink in the s-line bumper is lower down.
  16. Simonrich
    25
    They say that but the part number is identical. The s-line bumper is the same shape at the top but then the bottom turns in sharply, the flaps need reshaping to follow this.
  17. Daz Auto
    660
    201
    43
    Just checked - the rear mud flaps in the photo above had a part code of 8V3 075 101. The ones we have now have a code of 8V4 075 101. Have not had an opportunity to fit them yet, but they look right when holding them against the car.
  18. pat15312
    pat15312 Well-Known Member
    530
    253
    Wow that really does look horrendous :/
  19. Daz Auto
    660
    201
    43
    ****** Audi parts department :banghead: 3 door cars and 5 door cars have different mud flaps!
    Had an injury, so only attempted to fit the mud flaps today. We have a 5 door Sportback car!
    I had the 3 door rear mud flap swapped for the 5 door part. (see above) Fitted the rear mud flaps ok. Had to drill 2 holes - 1 in the rear bumper.
    I was assured that the front mud flaps were ok. Hmmm... ???
    Tried to fit the front mud flaps. The support under the car was about 1cm away from the surface to be mounted to.
    Had a good look at the 2 sets of instructions. The correct rear mud flaps clearly state an Audi A3 Sportback 2013. Diagram number 1 even shows a 5 door car.
    The front mud flap instructions just say Audi A3 2013. Diagram number 1 shows a 3 door car.
    Why the feck are my dealership trying to get me to fit the wrong ****** mud flaps to our new car?
    Just in case that is not clear - 3 door cars and 5 door cars have different mud flaps!!!
  20. gradwells
    gradwells Member
    79
    Sorry guys mud flaps ( also know as a means to increase air drag ) have no place on any modern car let alone a Audi -- dreadful .
  21. Daz Auto
    660
    201
    43
    ... in your narrow minded opinion!
    Many people who live in rural areas think mud flaps are a necessity.
    Edit to add: you are PA, where do I collect my £5? :)
    veeeight likes this.
  22. Daz Auto
    660
    201
    43
    ... this is why we will ALWAYS fit mud flaps...
    RAPS3 likes this.
