  2. Dismiss Notice
Running in ?
The Veteran Jan 4, 2020
  1. The Veteran
    The Veteran New Member
    What process did you follow when you ran in your new engines, I realise not everyone run there cars in but I would be interested to hear your thoughts on the subject.
  2. Avatar
    snack-media
    Advertisement
  3. Guest
    Guest Guest
    The trick with modern engines is to just drive steadily/normally from the start. Don't use large throttle openings. Do not to lug the engine at low speeds and don't be afraid to rev it a little (say 4000 rev/min) under light load right from the start. With modern oils, it's necessary to do this to make sure the engine components, particularly piston rings, bed in properly from the start. You only get one chance to bed the engine in. Don't change the engine oil early as new oil will reduce the bedding in of the engine.
    JS
  4. Bristle Hound
    Bristle Hound Moderator Staff Member Moderator
    10,787
    15,756
  5. The Veteran
    JS46, Thanks for that reply, Have always followed your recommendation in the past and I have commenced my RS3 pretty much as I have my past cars.
    Bristle Hound,thanks for that info which I found have found interesting and thought provoking .
