[h=2][FONT=Arial, Trebuchet MS, sans-serif, Georgia, Courier, Times New Roman, serif]I have had my RSNE version G scanned (thanks Amar) and have the below 2 errors which i think could be some of the cause i have for volume problems i have got. Has any one else come across these? and been able to fix them? any help would be appreciated [/FONT]
02005 - Coding Pin[/h][h=3]02005 - Coding Pin: No Communication[/h][h=4]Possible Causes[/h]
- Control Module Coding faulty
- Wiring faulty
- Check Control Module Coding
- Check Wiring
- When found in Radio/Navigation System RNS-E
- Check Coding for Sound System
- Check Wiring/Connectors (Connector B Pin 7 not wired)
- Radio Tuner not working
- Wiring/Connectors from/to Antenna Amplifier faulty
- Antenna Amplifier incompatible/faulty
- Check Wiring/Connectors from/to Antenna Amplifier
- Check Measuring Value Blocks (MVB)
- Check Antenna Amplifier
- Check Antenna Amplifier Part Number for Compatibility
