24styles
#teamsolar
you have to click on the little + next to the tyre size 255/30/ZR19 to get the rear size to come up
nope they are coming off an rs3, i got the dimensions off this website...
https://www.wheel-size.com/size/audi/rs3/2015/
and the owner is delivering them to me on sunday and has confirmed the sizes i have mentioned are the sizes that are on his wheels....
The wider wheel/tyre is 100% fitted on the front axel on the rs3. Designed to reduce understeer I believe
Sent from my SM-G928F using Tapatalk
If I had to run a staggered set up, then yes I probably would. Not sure I'd choose to go down the staggered route though....but would u run the wider wheels on the front of an s3??
There may well be S3 owners out there who have ran this staggered set up with good results?? In which case, my opinion would count for nothing.hmmmm.....wonder if anyone would want to swap ther 2 rears for my 2 fronts lol
I'd worry about front wing clearance (especially if you plan to lower it) as I'm sure the wings are wider on the RS3....
yea i know wot you mean, mine is allready lowered but only 20/25mm springs....but i will deffinatly have a good look for clearence
It will look very similar to fitting a 10mm spacer to your current 18" wheel but will also be 15mm closer to the suspension strut.
