Hi all
Looking to replace injectors for a new set was curious to whether anyone has installed the new revision RS4 injectors. Are they a direct fit for the AUDI S3 8P facelift apart from the plug/connector. Existing RS4 injectors are maxing out at 360bhp to a setup that's supposed to be on 400+bhp after serving only 15k miles hence the replacement.
2007/2008 RS4 injectors - 079 906 036 D (most commonly used).
New Revision b8+ RS4 injectors - 079 906 036 N (better spray pattern) use to be 079 906 036 T.
This is the only info online for them I've found:
"This injector can be used as an upgrade on the EA113 2.0T motor if you're running BIG power! These ones don't blow black smoke like the older version of the "RS4" injector, which has the same connector as the EA113 2.0T. These injectors have a different plug/connector"
