Rs3 traction control
RS3 FUN Oct 9, 2019
  1. RS3 FUN
    RS3 FUN New Member
    19
    My RS3 stage 1 in gears 1 and 2 has traction control numb acceleration when power comes on strong and I have turn traction control off so it doesn’t interfere.Does any 1 else suffer this.
  2. Avatar
    snack-media
    Advertisement
  3. RS03_SEN
    RS03_SEN Active Member
    201
    152
    43
    Yes. Some say it's because of the staggered tyre setup. IE 255/30/19 front and 235/35/19 rear.
    I've not tried having same tyre sizes front and back, I just turn the TC off soon as I get in the car.
    Sent from my GM1913 using Tapatalk
    RS3 FUN likes this.
  4. RS3 FUN
    RS3 FUN New Member
    19
    Just makes the car feel odd in 1st 2nd and just Erving smoothly with no power.
  5. Oli.
    Oli. Active Member
    612
    52
    What tyres you running?
  6. RS3 FUN
    RS3 FUN New Member
    19
    Standard tyres that came with the car Pirelli p zero
  7. Oli.
    Oli. Active Member
    612
    52
    I never noticed it on the Pirelli’s. But they are **** tyres. So far in 25k I’ve run conti 6’s in my 20’s, conti 5 in the standard setup and now 235 all round in PS4. All been good as gold traction wise.
    My 4-5 mm conti 5 staggered setup are for sale
    RS3 FUN likes this.
  8. RS03_SEN
    201
    152
    43
    Yeah it's terrible. No good the TC kicking in when you're trying to race someone. I use Michelin's all round but staggered sizes. Next time you buy tyres get 4 X 235/35/19 and see if that helps.
    RS3 FUN likes this.
  9. terminator x
    terminator x Well-Known Member
    4,249
    4,803
    Just press it once, TC issues gone.
    TX.
    RS3 FUN likes this.
  10. RS3 FUN
    RS3 FUN New Member
    19
    I have had time to try the car out with TC turned off and it pulls hard in 1st 2nd.
  11. Sug
    Sug Active Member
    187
    122
    43
    I turn it off straight away if I’m planning on having a bit of a blast on me own. I don’t loose much traction even at stage one. Unless your turning out of a junction in the wet and give it the beans then yes there will be a bit of slip. Tyre contact is only say the size of a CD so the haldex system isn’t a miracle worker. Turn it off and enjoy....but don’t Over do it
  12. Avatar
    snack-media
    Advertisement
  13. Slowracer
    Slowracer Active Member
    226
    131
    43
    There is an Audi fix to reduce the density of the traction control. I’d recommend getting it done, it’s a warranty item.
    Mine improved a lot with this fix and then even more with running square Michelin ps4s 255s. Pulling hard out of a corner is not an issue.
    mangobay likes this.
  14. T-800
    T-800 New Member
    26
    I'm currently running on 235 all round (was 255 fronts) Goodyear Eagle F1 Supersport tyres, no issues with traction control lights.
    Very good tyres and i give Goodyear regular feedback on how they are doing.
    Goodyear say the 255 version are about 10 months away from being available, but i'll stick with 235 all round.
  15. N-Sinc
    N-Sinc New Member
    25
    20
    Yes, this drives me insane. makes the car almost unusable with the TC on in the lower gears. It really is a joke.
    RS3 FUN likes this.
  16. Drewsus
    Drewsus New Member
    12
    I run 235 Pirelli P-Zero all round and very rarely have traction control kick in.
    DW81 and RS3 FUN like this.
  17. RS03_SEN
    201
    152
    43
    Don't even need to put foot down hard for mine to do it.
    RS3 FUN likes this.
  18. RS3 FUN
    RS3 FUN New Member
    19
    Certainly is annoying I have never had that on other cars in past it just dulls the moment.
  19. Drewsus
    Drewsus New Member
    12
    I test Drove a Nardo Grey PFL just before I ended up buying my Sepang Blue one a couple of weeks ago and it did exactly the that. The salesman tried to tell me it was normal and because we were going up a slight incline. It didn't help the fact it had a mis-matched tyre on one corner and had the 255 tyres on the rear and the 235 on the front. I ended up walking away and buying another after I heard him slagging me off saying that I had no idea how traction control works. He didn't realise I was in ear shot. The car is still for sale now, I can imagine it'll be for sale for a while unless someone buys into the bullshit.
  20. RS03_SEN
    201
    152
    43
    A 4wd car at 10mph in dry conditions under low acceleration shouldn't be kicking up the traction control. Mine does. I was convinced my haldex was broken. I just turn it off now when I get in the car.
  21. CWD
    CWD Member
    58
    37
    Never had any issues with tc on my fl I always drive in manual with most drive select settings in dynamic don't know if that has any baring on its sensitivity
  22. RS03_SEN
    201
    152
    43
    They have different size tyres on front and back?
  23. CWD
    CWD Member
    58
    37
    Yes I have the staggered setup
  24. Dan_DJT
    Dan_DJT RS3 Saloon Team Floret Silver Audi RS3
    247
    156
    43
    Perhaps stating the obvious but has your car def got both 255 tyres on the front ? If there is a mix the traction control doesn't like it. I've heard of a case where the wheels were fitted in the wrong location as the fitter didn't realise they were different sizes front to back.
    EVO855 likes this.
  25. EVO855
    EVO855 Member
    54
    45
    Wouldn’t be the first time either Dan
    The times I’ve read/spoke to RS3 owners when they’ve had tyres put in wrong.
    The other classic is mounting the directional tread the wrong way around on the rim
