RS3 8Y - Turn off or change artificial active sound volume
Lucasquattro
Stay hungry, stay foolish
Guys, just tried and succesfully managed to deactivate the soundaktuator on my 8Y via obdeleven.
I just hate how strong is the artificial sound when using Dynamic/Performance mode.
If anyone is interested, the coding is:
- [A9] (Structure Borne Sound);
- 10 - Adaption
- choose "Volume of structure borne noise actuator"
- Set value between 0 (off) and 100 (default)
- run the coding
I put down 0 and obdeleven arbitrarly registered 0,8%, but the effect is the same.
Now I officially need an aftermarket exhaust
8YARWY
Chasing the FB Mod trolls.......
- 10 - Adaption
- run the coding
Hmmm
I noticed OBD11 saying it had A9 when I was in SFD for something else, it came brought up A9 on a scan, which was weird because it has never seen an A9 module before.
Stranger still is VCDS and VCP do not show an A9 module.
RSt3ve
Well-Known Member
- 10 - Adaption
- run the coding
Can you confirm if this has reduced Engine noise, Exhaust noise or both?
So far my testing has shown only Engine noise is enhanced via the mode settings.
Spinstorm
To me it is all fake noise; doesn’t matter if it is actual noise sent into the front or amplified it wasn’t on the 8V and I don’t like it.
8YARWY
- 10 - Adaption
- run the coding
Indeed it’s there in VCP, but I had to type in A9 on a search of the modules.
Edit…..
It’s here in VCDS too but you have to search for it in direct entry, it’s not automatically listed
RSt3ve
Well-Known Member
Until someone does a proper under load video comparison with the fake noise generator on and off in all modes I have to go with what I've heard when my car has been driven away from me. These standstill videos prove nothing.
Yes it's quieter than a pre opf 8V, but it was never going to be louder, it's a different world we live in.
To the OP, still interested in your thoughts on my question.
8YARWY
And here’s an output test of it using VCDS
8YARWY
Just been out in it with the soundakator turned off.
It does indeed make the cabin quieter, I’m not sure if I’ll keep it off .
One bonus, I can here the actual rear exhaust noise more now.
RSt3ve
Well-Known Member
Awesome!!
Thanks for the feedback on this.
Lucasquattro
Had some tests today and I can confirm that the coding works properly and this setting is only related to engine sound, not exhaust.
Put the sound down to 0% with everything stock is not an option because the cabin is really well insulated and the exhaust..well, you know..
So I decided to recode the value up to 50% and I think it should be a right compromise for now.
8YARWY
Yeah just been out in it……very quiet inside now.
RS03???
I have also come to the same conclusion, leave it as is, using the MMI. Acid test was with the boss, on a 400miles ride on Motorway and mainly on A roads. No complaints from the passenger seat.
8YARWY
Probably wise, it seems the cabin goes from ‘loud’ to nothing.
3vans
What did it start off from factory as - 100%?
Lucasquattro
Yes, factory default is 100% which is too loud especially at low/medium rpm, definitely annoying imo
Keano04
Is there any fake noise in non RS modes?
Just trying to understand how it would sound when off - just like it auto mode say?
8YARWY
Prolly subdued in those modes.
Keano04
I think mine sounds best in auto s. Wasn’t sure if it’s still enhanced then, but I seem to get the most of the 5 cyl noise in that mode
8YARWY
I’m 50% less interior and 100% more exterior noise so it’s better now.
Lucasquattro
After turning off the artificial sound I can guarantee that it’s subtle also in comfort mode ‘cause I clearly heard the difference.
