Rs3 2018 TTE700
Bask04
My 2018 rs3 ,
Magnetic ride, and mss track kit.
But at high speed, the car feels not really steady,
Some tips are welcome
Will a rear swaybar help ?
Bask04
Have to ask about the obvious things: Was there magride recalibrated after the drop? Alignment done by a good shop? All suspension components checked for wear? If not, start there before you throw money at more parts.
Alignment is done by a proper company.
What about the recalibration?
I dont have it done.
Thank you
Aoon_M
Magnetic ride calibration will help a little but won't give you the result you desire, MSS kit/lowering springs/standard suspension all have this issue at high speed where the back end is uneasy, especially on a stage 3 car. The 034 motorsports rear sway bar does help a little with this but not enough I feel. I would highly recommend looking into a coilover kit!
wuta3
Recalibration is necessary when lowering a car with mag ride. Get it done and your ride quality and handling will improve. If your car is tramlining at speed your alignment may not be optimal for a lowered car. Factory alignment specs aren't always the way to go, but it is what most alignment shops will of course aim for. If your car is particularly low you may need adjustable sway bar links, as these all be cockeyed on a low car and not working as they should. 034 motorsports makes adjustable links for our cars.
Also, I noticed on the POS Pirelli rubber that the car tramlined at speed, since going for Pilot Sports that went away.
T-1000
Well-Known Member
Gold Supporter
Oke , but how to do it, click calibration , then done ?
Nope, other procedures that involve physical measuring of distance etc.
Aoon_M
