RNS E question
Topplumb1
Hi all
a quick question about the 2006 Audi RNS E, presumably my S4 V8 has its original unit installed, were these the 2D version? and are there any options that can be enabled via vcds and menus that can be viewed, looked at some stuff on you tube, but not found any instructions that run you through the whole sequence of what it can and can't do, some the versions have battery indicator and optical parking aid, does my unit have this ? and if so does it need to be enabled via vcds ?
Thanks.
norad97
Hi, I think you will find the answer is, no, no & no. look on VCDS Wiki it shows the progame options.
I think these option are B8 MMI.
