RNS-E Old Firmware needed
Ballantin Jul 18, 2017
  1. Ballantin
    Ballantin New Member VCDS Map User Gold Supporter TDi Audi A3 quattro S-line owners group
    15
    Hello guys,
    I upgraded my RNS-E from mk1 to mk2, and it worked perfectly.
    After some months it started to reboot itself at randome (it started about 2 weeks ago). Sometimes it will work correctly for the whole time, and sometimes it keeps reseting every 2 or 3 minutes. It is like when you switch the car on and off.
    VCDS says just that communication was interrupted, so it's hard to pinpoint where is the issue. I've checked that the cables are connected securely, removed the maps DVD, even tried removing the SD card. It still does it.
    I wan't to rule out a software issue, so I want to downgrade the Firmware version (already activated the downgrade option).
    The unit is in the only version that I got, I believe is 0660.
    Can someone let me know, or be kind enough to get my hands in a previous firmware version?
    I know that technically I should only get firmwares from original Audi DVDs, but I am not intending to use hacked maps or something similar, as soon as I downgrade the firmware, I will upgrade it again with my original Audi DVD.
    Thanks in advance.
  2. Avatar
    Google AdSense Advertisement
  3. mikep99
    mikep99 Active Member Team Phantom Audi RS4
    264
    121
    43
  4. Ballantin
    15
    You are right, I got version SW: 0220 HW: H06
    Any idea of where I can get a previous version? Unfortunately the post that you linked does not have 0150 anymore.
    Thanks.
  5. mikep99
    264
    121
    43
    I don't I'm afraid. Maybe worthwhile checking eBay for any old discs from before 220 was released.
    Mike
    Sent from my Nexus 5X using Tapatalk
  6. ch1z64
    ch1z64 C'mon you's bhoy's in Green Team Imola TFSI Owners Group Silver Supporter Team Sprint Audi S3 Manual
    3,298
    688
    i had an issue with my mk2 a little while back and it stemmed from my ignition switch as when i turned the car sw it send a pulse to the mk 2 which switched on and off could that fixed and issued disappeared , i know its a bit off of what u have posted but worth checking if it does that or when u start car up .
  7. Ballantin
    15
    It may be the case with mine too, the restarts are pretty much random.
    Anyone knows how to check it myself, or how much this can cost me (aprox)?
    Thanks guys.
  8. ch1z64
    3,298
    688
    Does your unit Flicker at times and screen disappears for a nano second if so it will be something in the ignition
