raz83
hi all
here is my log for my a4 convertible but I don't think the coding is right for a couple of reasons
one is it has bose and I had an a3 that had rns-e with bose and it was a 1000 times louder this one you turn the base up full and it just kicks in, also it has reverse sensors but I don't think they are coded in right on the rns-e either but it could just be me
any help would be much appreciated
regards
ryan
Saturday,15,November,2014,16:45:03:15102
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: WAUZZZ8H07K012690 License Plate: MM06
Mileage: 154500km-96001mi Repair Order:
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
63 65 67 73 75 76 77
VIN: WAUZZZ8H07K012690 Mileage: 154500km-96001miles
Address 01: Engine Labels: 03G-906-016-BPW.clb
Part No SW: 03G 906 016 KN HW: 03G 906 016 KN
Component: R4 2,0L EDC 000SG 9794
Revision: --H02--- Serial number:
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 79FFA2B630E3ACE9285-802C
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
Component: ESP8 FRONT H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004405
Shop #: WSC 00672 785 00200
VCID: 2C514BE28F31C941E33-8079
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 11
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0222
Hex Value: 0x0024
Hex Value: 0x018F
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BJ
Component: A4 Klimaautomat 2833
Coding: 00100
Shop #: WSC 00672
VCID: 6ADD8DFA16451771D1F-5156
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 20001
Shop #: WSC 00672
VCID: 3D7776A6374B50C944D-4B18
1 Fault Found:
02736 - Bulb for Tail/Fog Light; Left
30-00 - Open or Short to Plus
Address 15: Airbags Labels: 8H0-959-655-94.lbl
Part No SW: 8H0 959 655 E HW: 8H0 959 655 E
Component: Airbag 9.42 H09 1840
Revision: 92H09184 Serial number: 0037Y000F6J+
Coding: 0071114
VCID: 3C717BA27F5159C1733-8069
Subsystem 1 - Serial number: 6332BRB401098F90N
Subsystem 2 - Serial number: 6342BRB40109928EP
Subsystem 3 - Serial number: 63729RB401307D70E
Subsystem 4 - Serial number: 63829RB4013079206
1 Fault Found:
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 02011
Shop #: WSC 00672
VCID: 418F0A564BB33429205-4B30
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No SW: 8H0 920 950 Q HW: 8H0 920 950 Q
Component: KOMBI+WFS 4 H14 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0006411
Shop #: WSC 73249 020 01196
VCID: 3A7D7DBA766567F161F-5156
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Address 25: Immobilizer Labels: 8E0-920-9xx-8E2.lbl
Coding: 0006411
1 Fault Found:
Address 26: Auto Roof Labels: 8H0-959-255.lbl
Part No: 8H0 959 255 A
Component: VSG B6 CABRIO 6894
VCID: 3461538254019181BB3-5174
3 Faults Found:
02000 - Switch Position
008 - Implausible Signal - Intermittent
01986 - Convertible Top Frame Position Sensor (G356)
012 - Electrical Fault in Circuit
00532 - Supply Voltage B+
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 HW: 8P0 035 192
Component: RNS-E HIGH EU H52 0650
Revision: 07S Serial number: AUZBZ7D0300605
Coding: 0419717
Shop #: WSC 00720 123 06314
VCID: 6CD18BE24CB10941A33-5192
10 Faults Found:
02444 - Disk Drive Load / Eject Malfunction
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 21
Time Indication: 0
Date: 2012.02.22
Time: 08:58:49
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 3
Reset counter: 27
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 1404
Clock: 14:16
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00111110
Fault Priority: 5
Fault Frequency: 17
Reset counter: 27
Time Indication: 0
Date: 2012.09.26
Time: 12:44:34
Freeze Frame:
Mileage: 655350 km
Count: 702
Clock: 19:43
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 235
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
02005 - Coding Pin
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 235
Time Indication: 15
00857 - CD Changer Unit (R41)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 235
Time Indication: 0
Date: 2012.02.22
Time: 08:44:06
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Status: 00101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 23
Time Indication: 0
Date: 2012.02.22
Time: 08:43:03
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 238
Time Indication: 0
Date: 2012.04.14
Time: 12:14:05
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 23
Time Indication: 0
Date: 2012.02.22
Time: 08:43:37
Freeze Frame:
Bin. Bits: 10111011
Bin. Bits: 10
01305 - Databus for Infotainment
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 12
Reset counter: 23
Time Indication: 15
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8H0 951 178
Component: Innenraumueberw. 0411
Coding: 00001
Shop #: WSC 00000
VCID: 6FEB9CEE2DA7F259861-5156
1 Fault Found:
01839 - Transceiver Module 1 for Interior Monitoring (G303)
49-00 - No Communications
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8H0 959 433 K
Component: Komfortgerát T3B 5141
Coding: 06831
Shop #: WSC 00672
VCID: 3C717BA22C5159C1733-4B30
Subsystem 1 - Part No: 8H2959802D
Component: Tõrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8H2959801D
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 0002
5 Faults Found:
01616 - Signal Wire to Interior Monitor
49-10 - No Communications - Intermittent
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01560 - Passenger Door
60-10 - Won't Safe - Intermittent
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0419717
10 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 21
Time Indication: 0
Date: 2012.02.22
Time: 08:58:49
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 27
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 1404
Clock: 14:16
02261 - Data Medium
Freeze Frame:
Fault Priority: 5
Fault Frequency: 17
Reset counter: 27
Time Indication: 0
Date: 2012.09.26
Time: 12:44:34
Freeze Frame:
Mileage: 655350 km
Count: 702
Clock: 19:43
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 235
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 235
Time Indication: 15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 235
Time Indication: 0
Date: 2012.02.22
Time: 08:44:06
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 23
Time Indication: 0
Date: 2012.02.22
Time: 08:43:03
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 238
Time Indication: 0
Date: 2012.04.14
Time: 12:14:05
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 23
Time Indication: 0
Date: 2012.02.22
Time: 08:43:37
Freeze Frame:
Bin. Bits: 10111011
Bin. Bits: 10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 23
Time Indication: 15
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Revision: 00H06000 Serial number: 00067802020613
Coding: 0000024
VCID: 316F5A96AB13A4A9D05-5156
1 Fault Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 58
Reset counter: 28
Time Indication: 0
End-------------------------(Elapsed Time: 07:07)--------------------------
regards
ryan
Coding: 0000072
Coding: 0004405
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 11
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0222
Hex Value: 0x0024
Hex Value: 0x018F
Hex Value: 0x0001
Coding: 00100
Shop #: WSC 00672
Coding: 20001
Shop #: WSC 00672
1 Fault Found:
Coding: 0071114
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Coding: 02011
Shop #: WSC 00672
Coding: 0006411
1 Fault Found:
Coding: 0006411
1 Fault Found:
3 Faults Found:
Coding: 0419717
10 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 21
Time Indication: 0
Date: 2012.02.22
Time: 08:58:49
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 27
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 1404
Clock: 14:16
02261 - Data Medium
Freeze Frame:
Fault Priority: 5
Fault Frequency: 17
Reset counter: 27
Time Indication: 0
Date: 2012.09.26
Time: 12:44:34
Freeze Frame:
Mileage: 655350 km
Count: 702
Clock: 19:43
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 235
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 235
Time Indication: 15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 235
Time Indication: 0
Date: 2012.02.22
Time: 08:44:06
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 23
Time Indication: 0
Date: 2012.02.22
Time: 08:43:03
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 238
Time Indication: 0
Date: 2012.04.14
Time: 12:14:05
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 23
Time Indication: 0
Date: 2012.02.22
Time: 08:43:37
Freeze Frame:
Bin. Bits: 10111011
Bin. Bits: 10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 23
Time Indication: 15
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
Coding: 06831
Shop #: WSC 00672
5 Faults Found:
35-00 - -
35-00 - -
35-00 - -
Coding: 0419717
10 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 21
Time Indication: 0
Date: 2012.02.22
Time: 08:58:49
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 27
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 1404
Clock: 14:16
02261 - Data Medium
Freeze Frame:
Fault Priority: 5
Fault Frequency: 17
Reset counter: 27
Time Indication: 0
Date: 2012.09.26
Time: 12:44:34
Freeze Frame:
Mileage: 655350 km
Count: 702
Clock: 19:43
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 235
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 235
Time Indication: 15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 235
Time Indication: 0
Date: 2012.02.22
Time: 08:44:06
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 23
Time Indication: 0
Date: 2012.02.22
Time: 08:43:03
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 238
Time Indication: 0
Date: 2012.04.14
Time: 12:14:05
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 23
Time Indication: 0
Date: 2012.02.22
Time: 08:43:37
Freeze Frame:
Bin. Bits: 10111011
Bin. Bits: 10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 23
Time Indication: 15
Coding: 0000024
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 58
Reset counter: 28
Time Indication: 0
