RNS-E Bluetooth options
S3AMJ Sep 10, 2018
  1. S3AMJ
    S3AMJ OEM+ Team Brilliant Black Audi S3
    1,239
    341
  2. Avatar
    Google AdSense Advertisement
  3. Ashy>>
    Ashy>> Active Member
    115
    44
    Hi mate
    for mine i just went the simple option... an ebay RNSE female 3.5mm aux connector and an amazon bluetooth module with 3.5mm jack.
    works perfectly for my needs.
    https://www.ebay.co.uk/itm/3-5mm-Fe...600349?hash=item239dd161dd:g:BhMAAOSwHJVbMUxl
    AMAZON.co.uk MPOW bluetooth receiver - cant link it for some reason its the round one with 3.5mm jack and usb power
    can make and receive calls when RNSE is set to AUX setting and also stream music over bluetooth from my phone. The bluetooth adapter is pretty cool and you can select tracks with the little buttons on each side of it
  4. warren9022
    warren9022 Active Member
    440
    204
    43
    Depends what you want to spend, I personally think this is the best one on the market but it’s not cheap:
    https://www.dension.com/automotive/products/car-multimedia-solutions/gateway-pro-bt
    I’ve tried a few and none came close to this one, I’ve also added the DAB module that works flawlessly, just in case they ever turn off the analogue signal.
    Bit more hassle to fit as it comes pre-wired into a quad lock harness that will never fit behind the RNSE so you’ll have to wire it into the existing harness.
    S3AMJ likes this.
  5. S3AMJ
    1,239
    341
    Hey Ashy, thanks for your reply... I did look into this option, its cheap for sure but no real integration that I'm looking for. Would be nice to have the track info on the display and change tracks via the headunit button. plus I'm looking for handsfree to using the headunits telephone, etc.
  6. S3AMJ
    1,239
    341
    Hey Warren, I don't mind spending the money if it works. I want full integration as much as possible at least! I managed to scoop up my RNS-E dirt cheap so paying a little more to get it to work as I want it is all good. Just want to make sure I get the right stuff.
    On a slightly different but kind of relevant note, I've tried to change my start up screen to the S3 logo...... but when I change the value to (1) in channel 18 in navigation adaptions, it literally doesn't do anything... keeps changing back to (0)?! my RNS-E is 650 so above 500. VCDS won't give me the option to save the value for some reason. Any ideas mate?
  7. Tj 0785
    Tj 0785 Well-Known Member Silver Supporter VCDS Map User Bronze Supporter Audi S3
    2,686
    717
    Might be because car has to be coded as an a6
  8. S3AMJ
    1,239
    341
    Thats a very good point! I'm assuming then no has been able to to this?
  9. Tj 0785
    2,686
    717
    I looked into I’m sure it’s not possible only a a3/s3 could have s3 but ares are a “a6” you would think with all the things people could retro fit a ****** s3 logo shouldn’t be to hard
  10. warren9022
    440
    204
    43
    Yeah unfortunately you can only code the startup screen to match the vehicle you have the RNSE coded for so having the startup screen for an S3 when you've got it coded for an A6 is impossible. I've done a lot of searching and not found anyone that's been able to get round this.
  11. S3AMJ
    1,239
    341
    Dang oh well, small detail I guess..... Just annoying when its there in front of you and you cant do something so simple.
  12. Avatar
  13. S3AMJ
    1,239
    341
  14. Tj 0785
    2,686
    717
    Give dension a bell and see what’s they say I have or bite the bullet a retro fit one, they don’t cost that much when you consider how much it’s cost as an option on new cars
  15. S3AMJ
    1,239
    341
    I’ve dropped them an email they don’t seem to have a number I can call to contact them. I’ve been planning to do the multifunction steering wheel at some point for it way way down on the list of priorities at the moment... if I can get away with using the dension by pro without it for the time being then quids in, see what they say I’ll post my findings when I hear back from them
  16. Tj 0785
    2,686
    717
    Try this
  17. S3AMJ
    1,239
    341
    Thanks TJ, no one is available until Monday now. if I don't hear anything via email ill drop them a call. It does say on there website that you can use "either" the multifunctional steering wheels buttons, or the headunit buttons. but weather you have to have the steering wheel installed in order for the whole thing to work, I'll just have to wait and see what they say I guess.
  18. S3AMJ
    1,239
    341
    Right guys I’ve bought a genuine Audi Bluetooth module (8P0 862 335 H) complete with microphone, Bluetooth antenna and wiring harness for the RNS-E. Soon as I’ve got a weekend I can work on my car I’ll fit and code it in with VCDS.
    Reasoning behind this is because it’s really the only way you can get full integration with your phone and the RNS-E display and buttons plus the DIS.
    As for streaming music.... I’m going to go down the same route as @Ashy>> posted above, I’ve bought a RNS-E AV to 3.5mm AUX cable and I’ll code this in so AUX will be selectable via the headunit. Then I’ll buy a decent Bluetooth receiver and connect it to the 3.5mm output and an additional 12v feed. One that preferably auto-connects with your phone every time you get in the car and doesn’t stay on when the cars off draining the battery. This will all be hidden out of sight. Good thing about the new iPhone’s is you can connect to several Bluetooth devices..... so my theory is as soon as I get into the car and pair with both the Audi Bluetooth module and the 3.5mm Bluetooth receiver it’ll all work in harmony and I’ll use my phone for selecting music, which is no bad thing... radio stations, amazon music, Spotify, etc, etc.
  19. warren9022
    440
    204
    43
    The RNSE isn’t capable of displaying artist/track information from a third party Bluetooth streaming unit so the Denison unit uses the DIS to show all the information. The only way you can navigate through this information is with a MFSW......
  20. S3AMJ
    1,239
    341
    Thanks mate for confirming that, I hadn’t heard anything back from dension. This is why I’m going to go the route I’m going now. Genuine Audi Bluetooth phone module and Aux/Bluetooth for music streaming. I may consider an alternative down the line when I install a MFSW.
  21. warren9022
    440
    204
    43
    Trust me, you will soon get fed up of having to control everything through your phone. If your MFSW is a way off yet I have a Dension BT Lite for sale that will at least allow you to change tracks through the head unit.
  22. warren9022
    440
    204
    43
    You won’t regret it mate, the integration is spot on once it’s set up and working right :grinning:
    S3AMJ likes this.
  23. S3AMJ
    1,239
    341
    Thanks mate, just had a quick look and see you’ve got it for sale on eBay... the wiring is for the symphony 1 headunit. So ISO connectors rather than the small 12 pin block for the RNS-E quadlock. I’ll give it a miss on this occasion. My phone will usually be vent mounted by the steering wheel, so changing tracks, accepting calls, etc. Will be closer to me than the headunit. Until I get a MFSW I’ll stick to this method thanks for the offer though.
  24. warren9022
    440
    204
    43
    No worries. I had it running on the RNSE, just plugs into the other end of the adaptor. After being warned by PC Plod twice for use of a phone while driving I decided it was time to find something with better integration... :tearsofjoy:
  25. S3AMJ
    1,239
    341
    Oh they are hot on it these days! Slightly different topic but relative to the RNS-E what’s the max size SD cards we can put in it and does that display track names? I read somewhere the RNS-E MK1 can only take 4GB cards?
  26. warren9022
    440
    204
    43
    Yeah limited to 4GB on the Mk1. I believe it does display track names but never actually used it.
  27. S3AMJ
    1,239
    341
    Cheers thanks for your help Warren!
  28. S3AMJ
    1,239
    341
    Hey everyone,
    Right so I’ve fitted the OEM Bluetooth module and AUX 12 pin cable. Coded them in and AUX is working a treat. My iPhone 8 connects up to the Bluetooth phone module fine, can take calls and all works fine.....
    But, I can’t see how to dial or go through my phonebook via the RNSE. When someone calls it comes up and I can accept or decline the call. But finding someone to call doesn’t seem to be an option. All I’m getting is this message on the screen. Can anyone advise?
    My current code for the radio is - 0509251
    Thanks,
    Ash
  29. S3AMJ
    1,239
    341
    Right I’ve changed the coding now to - 0509751
    Getting more functionality with the RNSE. So can call numbers, etc.
    However still can’t seem to get my phonebook up?
    Any ideas?
  30. S3AMJ
    1,239
    341
    Ok for anyone else that’s got this issue! I’ve recoded the OEM Bluetooth module to the following code - 0010322
    This has now given me full integration with my phone and the RNSE for phone calls, phonebook, etc.
    In order to change the code you need to enter the Direct entry 77 via VCDS.
    <tuffty/> likes this.
  31. <tuffty/>
    23,393
    4,993
    You have to create a playlist file for the track names etc to be displayed... this is how I have mine currently...
    Folder layout on the card...
    A playlists content...
    Card selection on the RNS-E
    Tracks...
    ...and on my other card..
    I built the playlists using a bit of windows software when I first fitted the RNS-E... can't recall what it was called off hand but I spent a bit of time renaming files and you then pointed the software at it and it built the playlists
    I suspect you could hand build the lists anyway but I use my ipod for music most of the time... the cards are there as a fall back in case I forget it or if the family make a rare appearance in the car as they aren't trance/drum n bass fans lol
    S3AMJ likes this.
  32. S3AMJ
    1,239
    341
    Thanks PT,
    I think I’ll probably get a couple 4GB SD cards and whack some tracks on there for instant music. Can’t believe how sensitive the RNSE is with card types though! Apparently it has to be a non-HC SD Card. Which is harder to source and seem to be a lot more money now?!
  33. Avatar
  34. <tuffty/>
    23,393
    4,993
    4gb ones seem far and few between.. I use 2gb ones which I managed to get a few of but the two I showed there pretty much live in the unit... I don't change them at all other than to occasionally add singles I buy when having an iTunes moment...
    S3AMJ likes this.
