RNS-E Bluetooth enable telephone
IntsM
Riga
Hi guys,
I got Audi A2 A3 A4 A6 Adapter RNS-E Navigation Bluetooth Media Adapter From VAG Retrofit and installed it in my AUDI A3 Sportback 2007. Where can I find instructions how to enable it for use with my smartphone via Bluetooth?
Thanks, Ints
It’ll all need coding in. I think your best bet would be to find someone with VCDS from the map and ask them to activate it all for you but may be difficult right now with current restrictions.
Reactions: abmat
what about hidden menu? could it be possible to enable it from there?
Normally you can only get contacts to show on ur Dis from the Rnse thtough BT but depending on your model you might be able to use SDS.
Usually if u have a BT module you would just pair ur phone to unit
I cannot pair at all, BT module is not enabled. RNS-E shows ' Telephone is not installed'
U will need to get it coded to match what u have in car you could try and hold radio and setup together until screen reboots and see if the Aux appears in source worth a punt
801
NHN
