vala
On idle the engine in my car is hunting and not staying at a consistent rpm. Under load the car is fine and the revs rise and fall as they should. It even stays ok when I shift into neutral for a brief moment after being under load. But if I were to stop with the engine running, within 30-60secs again the revs will not be stable.
I noticed last time I drove the car the red oil pressure warning light came on. I swiftly came to a halt however as the revs came down the light would go out. I've had this problem before and it was solved through a clean pick up pipe and a new oil filter.
I think during the intake camshaft change I did recently some dirt my have entered the engine whilst I was cleaning the mating surface on the head (this is noted in a guide from here) and on the first oil and filter change I did noticed some of the crap on the filter. I'll be doing another oil and filter change on Tueaday along with rechecking (and if need be, cleaning) the pick up pipe.
So could low oil pressure cause the revs to not be stable at idle?
