Revo stage 2+ sps switch
Charlied_s3
Afternoon people! Had my map adjusted to revo stage 2+ yesterday and brought a sps switch just so I can have a play about with the map slightly I no all cars are differnt but just seeing what kind of settings people are running! Cheers
Marshy
Settled in
If your running 2+ then you'll have an uprated fuel pump?
Fuel settings are 9 for a standard pump and the lower the number you go the richer the mixture
Most run fuel 6 and if you turn the boost to 9 then richen the fuel slightly by selecting 5
What are your current settings?
s3_trev
Northern Ireland
Stage 2+ my best settings are
Boost 8 timing 5 fuel 9
How come mate? Thought you would be boost 9 and fuel around 6.
s3_trev
Northern Ireland
haha :highly amused:
Marshy
Settled in
When my car was Revo stage 1 I could run timing 6 no problem
Now on 2+ even with an upgraded intercooler timing 5 is best.
If I run timing 6 I get some timing pull and the car isn't as quick.
KentKid
Morning all!
I'm also Revo Stage 2+ and my settings are as follows:
Boost: 9
Fuelling: 5
Timing: 5
s3_trev
Northern Ireland
Those look like good settings KentKid. How do you find the car to drive? Also how are you finding the stage 3+ clutch?
KentKid
It drives brilliantly.
I’m on the linear map and it’s nice and progressive. It’s at its best above 4000rpm, and pulls hard right through the red line.
The Spec Stage 3 clutch is taking some getting used to, but that’s probably to be expected after 4 years of daily driving with the OEM clutch.
It’s a bit more heavy duty than the standard clutch, and I seem to be having problems selecting gears when driving flat-out; but I’m just going to put this down to adapting to the new clutch and giving it a bit of time to bed in.
I spoke to AMD about it and they said that it could be that the selector/cables on the box may just need resetting or adjusting.
Fingers crossed it eases in over the coming weeks; but if not AMD said they’d be happy to take a look and see if anything needs tweaking…
LVS Racing
Fuel should only be on 9 for stage 1 and 2
2+ requires uprated pump, once this is fitted fuel should be set around 5 or 6.
s3_trev
Northern Ireland
What if you have uprated pump and you are on stage 1 or 2?
s3_trev
Northern Ireland
Then again it would want to be knocked down BUT ideally I would recommend getting to into someone like ourselves and let us data log the vehicle down the road :)
So you mean if you have the upgraded pump the number should be lower than 9, regardless of what stage you are on? Just making sure I understand what you just said. And yes logging is a very good idea.
s3_trev
Northern Ireland
LVS Racing
Sorry I never got any emails to update me on this topic!! I`m soo sorry.
Yes you will only run 9 Fuel if you have a standard fuel pump and internals, once the Autotec Pump is fitted you always lower the fuelling, the uprated internals allow for a larger volume of fuel in the fuel rail. With the pumps fitted then I would run anywhere from 5,6 or maybe 7 fuelling.
Every engine is different (i.e 2.0tfsi) so that is why its crucial to data log the vehicle down the road and look at correction figures!! :)
