I bought a reverse camera kit and according to the manual found on this forum, I have to connect 2 pins into the quadlock 12-pin connector (CAN High and CAN LOW). Now, if I'm correctly, there is a chance that those slots (6 and 12) already got existing pins inserted.
The cable that came with the camera kit that should be connected to pin 6 and 12 is shown on the attached picture.
I see that they included a spliced connection with a black adaptor on it (A on the picture). I assume they made it so that I can pull the existing CAN High and Low wires (6 and 12) out of the grey-white (quadlock) connector and then insert the pins (B on the picture) into the grey-white connector? Could it be the idea of this is just like splicing wires?
Now my question is: the slots in this adapter is just large enough to fit these quite small (see picture) pins so I wonder if the pins of the existing CAN wires in the grey-white connector will alsof fit in this adapter?
Hopefully someone can give some information , thanks in advance
