Of course yep. I keep forgetting about the presence of the relay.
Funny story. As you can see below, the relay itself detaches from the wiring socket. So (when I was initially installing the relay), I wired it all up to the socket and nothing seemed to work properly. I read your tutorial post above countless times and swapped the wires over more than countless times!!! Traced back every inch of wiring around the reverse lights, camera and stereo lmao... Nothing seemed to work... Until I realised finally, I hadn't attached the relay to the socket and had wasted a good hour troubleshooting this!
The headlights bit is weirdly frustrating. Let's hope the delay is fixed
And hopefully, it should work every time I go into reverse?
I'm getting the same dash warning about one of my numberplate lights being blown. Haven't noticed whether its only with the engine/ignition. This has only started since I've installed the reverse camera.
My gosh, don't get me started on dash warnings for lights!
So between December and February (I installed my aftermarket stereo in November 2017 - not sure if this contributed as have been told by a local car electrician that aftermarket stereo's cause electrical faults? Not sure how true this is..), I occasionally had the odd dash warning, generally halfway through a journey that a light wasn't working. And once one of these dash warnings appeared, I'd probably have another 2-3 warnings for different exterior lights. These messages ranged from any of my front headlights, fog lights, rear tail lights, reverse lights, brake lights, and numberplate lights. So pretty much every exterior light on the car would occasionally give me a warning message(except indicator lights). And it wasn't just the message - these lights were actually not working for the time the message was there. But if I turned the engine off, these messages would generally go away for a while. Then they may return later(maybe minutes, hours or days), but not necessarily for the same light - it could be different exterior lights. To my knowledge, the indicator lights were working fine even though a lot of the others were not.
Mid March - I drove up to Scotland (from Birmingham) for a few days. Decided to return on a Sunday afternoon. Left at approx 3pm and had a 10 hour non stop drive ahead of me from Inverness back down to London(was visiting family there) - but as I had the family and kids with me, with about 110 breaks it took us 14 hours. About 30 minutes after we left Inverness, I was bombarded with every ****** dash warning (for lights) that you can imagine, except the indicator lights. Tried turning the engine off and back on. Every time I switched on the engine(naturally I have my foot on the brake as soon as i get in the car) - I'd get those irritating dash warnings with the ****** BLEEEP noise for the brake lights. Then, once I turned on my headlights/DRL, I'd get warning lights for all of these(except for front left headlight and rear right tail light). And the same for reverse lights, as soon as I reversed. I had to make the journey back regardless of whether or not the lights worked and as it was a Sunday evening, couldn't even visit a garage. So I decided to drive the whole way with hazard lights. Once we had reached the M25 - we were pulled over by a lovely convoy of police cars who kindly let me know that asides from the one tail light and one headlight - none of my lights were working at all EXCEPT for my rear right indicator. So instead of hazard lights, it looked like I was ****** indicating right(only from behind)!!!!!!!!!!!!!!!!!!! Called recovery to take us the rest of the journey, as per the request of the police, even though we were 20 minutes from our destination lol...
Anyways, took it to a garage the next day and he didn't speak much english so I didn't quite get what he was doing. Looked light he was using a voltmeter to check all the lights. Then he told me he's giving all the lights direct electricity. He did this with his voltmeter I believe. As soon as he did this to each light, they (one by one) started working again.
This issue has been fine since then, but last week it's starting to come back (little by little) and now I'm back to the same stage as I was in December.
Weird right?!!!
Ahah this pwm stuff makes sense and seems to explain why the camera's playing up.
I'm hoping I've used the correct cable for the wiper motor that I think is the 'live' cable. I read on this forum and a few others and came to a conclusion that it was the 4th cable in the socket thing (the black and brown one). I think that a voltmeter would be very useful to invest in. Will have to order that later today.
