SweatySweater
I am attempting to retrofit a MK3 TTRS steering wheel, Virtual Cockpit, MIB2, and Carplay into my Pre Face Lift S3.
The updated steering wheel is necessary to have access to the "VIEW" button, to change display settings on the VC.
I will pre-face this by saying that I haven't found another thread with a car in the US, that has been capable of retrofitting the VC, or even attempted. I know there are a few guys in EU that have done this, and now MK7 Active Display retrofits are popping up here in the US as well. I have seen a couple of people that have retrofitted the TTRS wheel into the MQB cars with only partial functions. I am hoping that we can have the wheel, VC, and MIB2 work 100%.
My first challenge was to find a MIB2 Unit that could have NAR maps installed, and them work correctly, and also have CarPlay. Sirius and DAB (Digital Radio) aren't really a huge concern of mine. I created a list of part numbers of MIB2 units from US MQB cars with Parts Link. Unfortunately with it only being around for a couple of years so far, the cheapest NAR MIB2 unit I could find was still $4k +. This simply is not an option due to the total cost that the project would come to. After speaking with multiple companies over sea, I ended up working with APG in Poland who specializes in retrofitting MIB/Clusters.
They say they are able to source me a MIB2 unit, with NAR maps installed, CarPlay enabled, Sirius, and DAB. For those not familiar, Audi and VW now uses SwaP codes to unlock these features on cars that wish to upgrade. After researching, even though my S3 came with NAV, it is not the Google Maps style of Nav on the new cars. My VIN also isn't eligible for the CarPlay FEC code due to it not being available during my production or MIB1. It seemed as though my only option was to get an unlocked unit.
And here we are, at the beginning of this long road. I will say again, I am not sure that the VC will work 100% but I want to get it as close as possible and have this serve as the guide to help people who wish to do this in the future.
Parts that have been ordered so far:
-TTRS Steering wheel with airbag and harness
-LCD Instrument Cluster: 8V0-920-790-A
-MIB 2 Unit: 8V1-035-035 (There are multiple part numbers for this, depending on features and it is region specific)
-LCD Trim: 8V0-857-115
-HSD and MOST cables to run from the back of the MIB2 to the LCD
-Adapter harness for Cluster (Original is 18 pin, new cluster is 32 pin)
-Bracket for mounting LCD
-USB port for CarPlay and wiring
While we wait for the VC parts to arrive, the steering wheel needs to be installed.
Plug and play does work with the new steering wheel. The airbag connectors are different, but can easily be swapped. Both airbags are however, 1 stage airbags.
Here is where I ask for the first bit of help. The S3/A3 has a clockspring F350, separate from the the Steering Column Control Module J527. The TTRS using a 1 piece design that houses the clockspring, wiper stalk, and cruise control stalk. Here is the wiring layout for the yellow 12 pin connector on the clockspring from both steering wheels.
S3:
Pin 1:
Pin 2:
Pin 3: Black wire, Ground for N95 Igniter
Pin 4: Green wire, Power for N95 Igniter
Pin 5:
Pin 6:
Pin 7: Brown wire, Ground Connection that also goes to the Horn, and pin 3 of T4 connector on steering wheel.
Pin 8: Blue wire, Power for horn function, constant B+
Pin 9: Purple wire, LIN Bus, goes to Pin 1 of T4 on steering wheel.
Pin 10: White wire, constant B+ for steering wheel, goes to Pin 2 of T4 on steering wheel.
Pin 11: (Has pin on Clockspring, but no wire from steering wheel)
Pin 12:
TTRS:
Pin 1: Gray wire, goes to Pin 2 of T4 connector for Start/Stop and Drive Select Buttons (Unknown Function)
Pin 2: Light gray wire, goes to Pin 1 of T4 connector for Start/Stop and Drive Select Buttons (Unknown Function)
Pin 5:
Pin 6:
Pin 7:
Pin 8: Brown wire, Ground Connection that also goes to the Horn, and pin 3 of T6 connector on steering wheel.
Pin 9: Purple wire, LIN Bus, goes to Pin 1 of T6 on steering wheel.
Pin 10: Red wire, constant B+ for steering wheel, goes to Pin 2 of T6 on steering wheel.
Pin 11: Gray w/ Red Stripe wire, goes to Pin 3 of T4 connector for Start/Stop and Drive Select Buttons
Pin 12:
I was able to get basic functions working on the wheel. 80% of the buttons, the lights, and the horn.
Using the harness from the TTRS wheel:
Move the brown wire from Pin 8 to Pin 7. Its that simple.
This gives you Purple, Red, and Brown on the T6 Connector at the top of the wheel. This provides all the basic functions.
The wheel has a T4 connector with 3 wires for the Start/ Stop and Drive select Buttons. Only 3 wires. The S3 clockspring only has 2 remaining pins though.
Pin 8, and Pin 11. Both of which have B+ when the key is on, and again, I am left with 3 wires for those two buttons.
Are these wires Power, Ground, and LIN?
Signal, signal, and ground?
The wiring diagram is very vague and only has the wires listed as black. No colors are listed. Another fun fact, is the Start/Stop button currently also activates the horn :thumbs:
Here is the new harness once adjusted. Note, there is 1 gray Power wire going to the T4 connector at this time. I am unsure of the purpose of this wire at this time.
And here is a photo of the wheel installed with no airbag. You can see the clockspring with 2 pins on the top row, and 5 on the bottom, as well as the T6 connector above it.
And here is the T4 connector that is simply for the Start / Stop and Drive Select Buttons.
And for reference, here is the wiring diagram for the S3 followed by the diagram for the TTRS. If anyone would like to chime in and help solve this, that would be great. You can see all the black wires that are built within the TTRS wheel in the 3rd and 4th photo.
and the TTRS
There will be more updates as this progresses, and as parts arrive for the MIB and Virtual Cockpit! Any info, help, tips, etc, are greatly appreciated! I look forward to seeing this progress!
and here is an AutoScan just because.
S3:
Pin 1:
Pin 2:
Pin 5:
Pin 6:
Pin 12:
TTRS:
Pin 5:
Pin 6:
Pin 7:
Pin 12:
and the TTRS
Code:
Thursday,11,October,2018,13:33:26:16731
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 18.9.0.2 HEX-NET CB: 0.4436.4
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WAUBFGFF8F1xxxxxx License Plate:
Mileage: 69245km-43026mi Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 52 55 5F A9 BB BC
VIN: WAUBFGFF8F1xxxxxx Mileage: 69245km-43026miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H52 4521
Revision: 05852204 Serial number: TFK01405260976
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1F0E0B4706FC87B2CC-804A
No fault code found.
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 61574000002972
Coding: 31FF6B9254230A70017F030341C4698CD62A5080C08296B6024100588608
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
VCID: 45C2B92FC4E0BD62A6-8010
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0337502114
Coding: 030C0C
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3A38DAD3BD1EC29ADB-806E
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000352798
Coding: 03000014010000000000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 3326F7F79A7433D218-8066
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 8E28C137000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 085 AC HW: 5Q0 937 085 AC
Component: BCM MQBAB HNA H18 0134
Serial number: 01011415600179
Coding: 04151A46C04122F541C04004511807A00800000000000000000000000000
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_013.rod
VCID: 7AB81AD3FD9E029A9B-802E
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 140607 042 0585
Serial number: 140616050335
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22746941
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 K HW: 8V0 941 531 K
Component: E1 - LDS MQB H05 0032
Serial number: 13 04 2014 00001159
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000030053299
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO30038644
Coding: 101F00
2 Faults Found:
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 195
Date: 2000.00.00
Time: 00:00:00
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 195
Mileage: 69245 km
Date: 2018.10.11
Time: 13:27:30
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 009 0825
Serial number: 003GCR00FAC9
Coding: 9DCCFCC0000000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002138
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47DEB327FEECAF7254-8012
Belt Pretensioner left:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H35 0341
Serial number: 34178311A16061440949
Coding: 333135
Belt Pretensioner right:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H35 0341
Serial number: 34178312A16061440726
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y1400015LZP0G
Coding: 303230
Side Sensor Driver Front:
Subsystem 4 - Part No SW: ----------- HW: 480 001 106 14
Component: SideSensor_Df 001 0887
Serial number: 35700000000EB8309F0W
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 5 - Part No SW: ----------- HW: 480 001 106 14
Component: SideSensor_Pf 001 0887
Serial number: 358000000006B8309F0P
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 6 - Part No SW: ----------- HW: 480 400 406 14
Component: SideSensor_Dr 001 6149
Serial number: 3510002B5156EA05B171
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 7 - Part No SW: ----------- HW: 480 400 406 14
Component: SideSensor_Pr 001 6149
Serial number: 3520002C3156EA01B1C2
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 8 - Part No SW: ----------- HW: 480 401 004 14
Component: FrontSensor_D 001 6149
Serial number: 3550002C31529DF1C248
Coding: 2D2D2D
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 401 004 14
Component: FrontSensor_P 001 6149
Serial number: 3560002C31529DF2E24C
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 CP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 18061408490796
Coding: A218
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_012_AU37.rod
VCID: 0A584A13AD7E121A8B-805E
1 Fault Found:
227387 - Windshield Wiper/Washer Switch
B1149 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 69245 km
Date: 2018.10.11
Time: 13:02:24
Operating time: 87989 min
Supply voltage: Terminal 30: 12.4 V
Vehicle speed: 0 km/h
Voltage at switch: 4.98 V
Terminal 15 status: active
System status: 30
FF U Wischer AD value: 230
FF U Wish Wash AD value: 229
FF U Intervall Poti AD value: 61
FF U MFA AD value: 252
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 970 S HW: 8V0 920 970 S
Component: KOMBI H02 4291
Coding: 0BED181B2B80D7050201E8001800000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009040
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 4CD48C0BE78A4C2A79-8018
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 11061410800771
Coding: 0101000820085A005B00022C180B00000001010000000000000000000000
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti_011_VW37.rod
VCID: 42C8A233D5CE8A5A83-8016
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8S0 951 523 K HW: 8S0 951 523 K
Component: J453 MFL H01 0002
Serial number: 20170220132047 RD128
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Component: Haldex4Motion H52 7076
Serial number: HA1-00013.05.14
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002001
ROD: EV_AllWheelContrHA1VW37X.rod
VCID: 46C0BE23F9E6B67AAF-8012
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000152811004
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 3424F4EB9F7A34EA01-8060
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 30051402090339
Coding: 00101F204000048000000002
ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 3E30D6C3A136EEBAE7-806A
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8102
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
VCID: 3522C9EF94002DE236-8060
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
Component: TSG BFS 020 0025
Serial number: 01061401101471
Coding: 001017204000048000000002
ASAM Dataset: EV_DCUPasseSideEWMINKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 3D32D1CFAC30F5A2FE-8068
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 012A000101000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75A209EFD4806DE2F6-8020
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 8V0 035 039 C HW: 8V0 035 039 B
Component: MU-H-LNS-US H44 0403
Serial number: A539A0J7505175
Coding: 01730102FF0A000021220001041A00102F000205010001047E
Shop #: WSC 29707 001 1048576
ASAM Dataset: EV_MUHig6C3HBAS 001040
ROD: EV_MUHig6C3HBAS_AU37.rod
Data medium:
Subsystem 1 - Part No SW: V03 959 800 T HW: -----------
Component: NAR 2016 --- 0048
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0013
Serial number: AUZ8Z9EY201511
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 S HW: 8V0 919 614 E
Component: ControlUnit_H H64 0766
Serial number: C1000022051400020165
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 3006
3 Faults Found:
0020 - Tuner for Satelite Radio
B11CF 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 124
Mileage: 54940 km
Date: 2018.02.22
Time: 13:58:48
Voltage terminal 30: 12.6 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: No_signal
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
3084 - GSM antenna 2
B1533 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 19
Reset counter: 129
Mileage: 54940 km
Date: 2018.02.22
Time: 13:58:49
Voltage terminal 30: 12.5 V
6708 - Databus
U1121 00 [008] - Missing Message
[Engine: no communication]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 235
Mileage: 67082 km
Date: 2018.08.31
Time: 17:50:52
Voltage terminal 30: 14.6 V
Network diagnosis-Status: Enabled
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 140521201825
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 7DB211CFECB035A2BE-8028
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 395 B HW: 5Q0 959 395 B
Component: TSG HFS 020 0025
Serial number: 10061404081400
Coding: 000017204000048000000002
ASAM Dataset: EV_DCURearDriveMINKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 40CCA83BDBC2984A95-8014
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0025
Serial number: 10061403111400
ASAM Dataset: EV_DCURearPasseMINKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End----------(Elapsed Time: 01:57, VBatt start/end: 12.6V/12.6V)-----------
Address 16: DTCs cleared
