Retrofit Reverse Camera
Rjp
So I’ve done some more digging over the last couple of days. The first image is of my car N/S/F of the dash fuse box (T46s)? As in the diagram shows it on the O/S/F. But on mine I have (T46i)? And in the drawings CAN low and high connect to location (T46s) pin 15? And the fuse on the manuals say 5amp location (ST5) F6?
Thanks For help and I hope this helps others
KayOG
Depends, I bought the kit from Kufatec but then ended up needing some extra cables as I didn't like how they said you should wire direct from the controller to the door mirror with no joins, as such you could not easily remove the mirror or door if needed. I think @Audidave69 already has the side mirrors so is looking to add the controller, swap the rear camera and add the front grille one.
Pardon my ignorance. But how will this affect your warranty? I did explore retrofitting the 360 degree camera but i wasn't sure if this would void my warranty.
Cem Dogan
Dear All,
I have retrofitted 6C reverse camera to my 2018 A5 sportsback.
Followed this;
19 > Installation List > add 6C
5F > Adaptations > VPS > Active
5F > Adaptations > VPS Message Bus > Comfort
I get camera view and moving lines.(see attachment) But it doesnt always show up. Especially it doesnt show up when i needed to see.
I read the posts it is recommended to code 10 > Park/Steer Assist -> Long Coding -> Byte 2 > Bits 4-5 = 10 But i dont have module 10.
6C and 5F doesn't give any errors when i do scan.
How can I get it properly coded?
My modules are below;
01-Engine
02-Auto Trans
03-ABS Brakes
08-Auto HVAC
09-Cent. Elect.
13-Auto Dist. Reg
15-Airbags
16-Steering wheel
17-Instruments
19-CAN Gateway
29-Left Light
39-Right Light
42-Door Elect, Driver
44-Steering Assist
46-Central Conv.
52-Door Elect, Pass.
5F-Information Electr.
6C-Back-up Cam.
6D-Trunk Elect.
80-Batt. reg. aux. accum.
81-Gear Shift
8B-Adaptive Cruise 2
A5-Frt Sens. Drv. Assist
BB-Door Rear Drv
BC-Door Rear Pass
D6-Light Ctrl Left 2
D7-Light Ctrl Right 2
@DJAlix
Cem Dogan
I think I found the issue,
5F long coding RVC was set to Low. recoded and it is displaying as it should be.
Hello all,
Anyone willing to retrofit a parking camera on the Audi A3 S Line 35 TFSI 150, 2019, or recommend a place that can, in Birmingham?
DM, if you can assist.
Thank you :D
DJAlix
VAG Car Coding™ Limited
Site Sponsor
Gold Supporter
VAG Can Professional
ODIS (Offboard Diagnostic System)
Pop down to London for the day so I can complete the works for you :)
DJAlix
Site Sponsor
Gold Supporter
DJAlix
Site Sponsor
Gold Supporter
