Retrofit Reverse Camera
KrisKrk
A6 C6 4F 2010 LeMans Avant
If you’re in London, @DJAlix will be your guy
DJAlix
VAG Car Coding™ Limited
Site Sponsor
Gold Supporter
VAG Can Professional
ODIS (Offboard Diagnostic System)
crag364uk
I am also based in the midlands. Did you manage to get this done in the end? Looking for some prices here to.
DarkyUK
DaveM
The Kufatec ad mentions coding required, is that done using the USB included in the kit, if so is it a simple operation?
DarkyUK
The Kufatec dongles generally do all the coding for you, switch ignition on without engine running, plug in and let it do it's stuff.
DarkyUK
It wasn't hard when I did it on the A7, the 360 camera I added to the s5 is a totally different job though....
You will need to remove the inside trim on the boot to get the camera in and then run some cables, mainly plug and play with the kits and usually all genuine parts other than wiring.
DarkyUK
Generally you will be adding additional wiring to the existing loom and connectors.
DarkyUK
DarkyUK
What sort of cost are u looking at ? Pm if u want
Depends, I bought the kit from Kufatec but then ended up needing some extra cables as I didn't like how they said you should wire direct from the controller to the door mirror with no joins, as such you could not easily remove the mirror or door if needed. I think @Audidave69 already has the side mirrors so is looking to add the controller, swap the rear camera and add the front grille one.
mickwillow
I have missed my rear camera since having the b9, Would my folding door mirrors need to be changed or can they have the camera added to them?
DarkyUK
I’ve just been measuring all the fakra cables tonight, €#€#$$% hell there expensive :sadlike:
Yeah, the new 4 wire ones are! Whats the price like on the cabling kit from Kufatec? You would then only need the two extra patch cables that I added if you want to be able to split the cable in the car to remove the door
DarkyUK
Audidave69
Torchbearer115
After reading this forum I have now ordered the kit from Kufatec, lets hope for a dry day next weekend to see IF I can get it fitted.
DaveM
Would be interested in any feedback and/or pics from your experience fitting the Kufatec camera. I helped fit one to my son’s Mazda, so hope it’s as straight forward. Good luck.
DarkyUK
It’s still in the box, not had time to fit it yet. And looking for my brave pants to start taking my brand new car apart
Its fun taking new cars to bits, I have some great photos of my S5 with no bumpers on and a naked boot and back seat when we added the Side Assist and 360 Camera :)
