Jlambert
- Joined
- Feb 23, 2013
- Messages
- 62
- Reaction score
- 42
- Points
- 18
Hi all,
I've gone through so many threads and tried all the suggested tricks.
I've tried to retro fit cruise control to my 2005 3 Door A3.
Its a midline control module with no mfsw, but with DIS.
It's an earlier module
1KO 953 549F
But coded correctly to 42 value from 12
I followed the guide on here which was brilliant. With my car being an earlier 3 door I thought it'd need the extra supplied cable. But after checking the connection block it already has the black and white cable in the number 13 slot.
Just to check I also tried to access the radiator tank coupling station, but after pulling off the scuttle cover, wiper motor then the cover. It would seem I don't have one!?
I've coded the car using VCDS, changing the soft coding in the steering control, and the coding 2 value in the engine ecu.
And waiting with the ignition off.
In the steering module I can open the ccs readings. And it recognises the increase in speed, decrease and speed cancel. But I can't activate it.
Any help would be greatly appreciated!
Joe
1KO 953 549F
Joe
