  2. Dismiss Notice
Retro fitting auto lights on a Audi a3 2015
Josh Schofield Oct 13, 2019
  1. Josh Schofield
    Josh Schofield New Member
    Hi I am new to this forum and new to audi after owning vw golfs anyway got a 2015 audi sline a3 but it ain't got auto lights can they be programmed to work using something like carista or do u need to get some retro fit kit would love some help on this one please
  2. Avatar
    snack-media
    Advertisement
  3. NHN
    30,475
    2,012
    Depends on hardware initially & coding, something I've done for other owners.
  4. Josh Schofield
    How would I know
    Sent from my SM-G975F using Tapatalk
  5. NHN
    30,475
    2,012
    Light sensor & of course auto position on the headlight switch, if the switch isn't in place then you'll need hardware.
  6. Josh Schofield
    No auto position on the light switch so I guess no light sensor so guessing I will need a auto light switch for starters
  7. 88rsr
    88rsr New Member
    10
    The rain and light sensor are mounted in a bracket on the windscreen wjich the rear view mirror clips over. If you wanted it factory you would have to have a new screen, new rear view mirror, along with the sensor itself and a new light switch.
    Failing that I believe you can buy kits which include a stick on light sensor to attach to the screen and a new light switch or there are variants where you tap into the wiring and it overrides the light switch when the sensor detects low light.
  8. DJAlix
    DJAlix VAG Car Coding™ Site Sponsor Team Ibis VAG Can Professional Gold Supporter VCDS Map User quattro ODIS (Offboard Diagnostic System)
    5,428
    4,280
    Nope, new screen not required for MQB cars. Pop the mirror off and remove humidity sensor and replace with rain, light and humidity sensor. Swap light switch for one with auto position, make needed coding changes and enjoy auto lights, wipers and coming home / leaving home lights.
    I do a number of these retrofits every week from my location in north London.
    Josh Schofield likes this.
  9. Josh Schofield
    So mine is a 2015 a3 sline to get coming home lights would I just have to get the sensor in the mirror and auto light switch replacement the car has day time running lights and auto climate did read somewhere this can make a difference
  10. DJAlix
    5,428
    4,280
    + coding yes
  11. Josh Schofield
    So how do u go about coding can u do it yourself or do you need a garage many thanks
  12. Avatar
    snack-media
    Advertisement
  13. DJAlix
    5,428
    4,280
    Need a coding tool / application like VCDS or alike and the needed codings, visit someone like myself who can offer the complete retrofit, fit and code your supplied parts or just code your install.
  14. Josh Schofield
    Where are u based to bud and how much do u charge to do a refit
  15. DJAlix
    5,428
    4,280
    Based in Muswell Hill, North London and would ask £280.00 supplied, fitted and coded.
    Am fully insured, only new Genuine OEM Audi parts are used and I supply a 2 years parts warranty and 2 years installation warranty.
