cut the clips off, use a hammer to knock it off the shaft, replace the circlip on the shaft, grease the end of said shaft.
slide the new gaiter and clip on, fill gaiter with grease, fit new joint, put gaiter over joint, tighten clips... and reassemble the other bits...?
