Hi All, I am guessing this has been covered before but I have done some searching and not found a solid answer. I have a Brembo GT Jnr kit on my S3 and the rotors are just about past their used by date. I have contacted the brembo dealer here in Australia who was not overly helpful. I was wondering if you guys could point me in the right direction? Preferably I would like a 2 piece slotted rotor but if I can only get 1 piece ones that fine I just need to be able to get something as mine are almost dead. Are these rotors the same as the factory ones on the LCR? Cheers -Nathan
Standard LCR are plain faced discs...and they work fine. Get them from any SEAT dealer. Or any aftermarket LCR disc in either cross drilled or grooved will work.
Yep same as OEM LCR discs. Can you get EBC stuff over there? I'm using EBC Ultimax on mine at the mo and so far so good.
I was unsure is the LCR were the same as from what I have seen they are smaller rotors? Maybe the ones I were looking at were not the brembo versions? as it said they were only 312mm? We never got the LCR here in Aus so is a bit hard to talk to anyone who has a clue about them. Cheers for the help
Getting sick of not finding the right size, I must be looking in the wrong spot, but every website I seem to find only lists 312mm rotors and not the 323mm can someone please point me in the right direction :S.
Leon Cupra = 312mm Leon Cupra R = 323mm and Brembo 4 pot callipers. Not sure where to try to get them from though...especially for you.
I dont mind buying them from the UK, I have contacted Bill in the hope that he still does this 330mm 2 Piece ones that I was reading about earlier. Hopefully that will be my solution
These work well and are not that expensive (see LCR 2002-05); http://www.brakes4u.co.uk/supersearch.asp?step3=yes&catType=C&catParent=2&pMake=SEAT Not sure if you can source in Australia though? EBC don't list australia on their website. Might be expensive to import.
replied.. 330mm 2-piece upgrade kit.. if sourcing locally (you in Oz?) the D1338 are plain EBC number or USR1338 is Ultimax grooved versions... and they work very well with DS2500 ferodo pads regards bill
We do get EBC over here, infact I know one of the reps, but as we never got the LCR over here I did not even bother asking him. I will pass on those parts numbers and see what he comes up with. Thanks for everyones help. Also Bill I have replied to your PM.
I'm running EBC Ultimax discs with Ferrodo DS2500 pads on my Brembos on Bill's recommendations and I concur they work well.
