Removing rear reading lights
Derv_guzzler
Hi can somebody please explain to me, how to remove the rear reading lights? I can clip off the first cover, but for the life of me, I can't pop out the whole fitting in order to gain access to the rear of the bulbs?
Thanks in advance
Derv_guzzler
When I done my A7, i had to take out the whole fitting and then change the bulbs
Hi Bishop
Yes that is what I thought, but I am unclear as to how you "take out the whole fitting"? Is there a screw, or do you just need to "brute-force" it? Or does it need a special tool to pinch some retainers somewhere?
Bishop187
Hi Bishop
I done mine a few years ago. From what I can remember it was a pain in the ****. I believe it’s just clips. I used a plastic pry tool but then ended up used a butter knife to pry it out. U just gotta go slow. It took me bout 30mins to get it out but i was being very cautious
Bulldog
When I did mine I used a pair of long nose pliers with a microfibre in between & gently pulled them out. Took all of 5 mins start to finish.
