Removing fine marks/scratches
DotNetDude Oct 18, 2018
  1. DotNetDude
    DotNetDude Active Member TDi Audi A6 Audi Avant Owner Group S-line owners group
    133
    61
    Hi All,
    I've got a number of fine "scratches" down the nearside, an unfortunate consequence of needing to use a narrow road over the past 2 years! I spoke to a mobile valet who said that a hand polish would stop the marks from being visible, albeit only temporarily; to get them removed permanently would require a machine polish.
    I opted for the "full exterior valet with hand polish", and he was quite clear that he wasn't "removing" the scratches, but the effect of them not being there should last for a couple of months. However the shine was lost quite quickly afterwards, and after just 2 weeks I can see the light scratches again. I'm pretty disappointed that it didn't last that long - for £140, are my expectations unreasonable, or is the only way to remove them to pay for the hand polish?
    Note that I refer to them as "scratches", but my fingernail doesn't feel them, they are just marks on the surface that look like scratches, if that makes sense. I'll be selling the car soon, not sure whether to try to deal with them properly , or leave them for the next owner to deal with (and lose a bit of money on the sale).
  2. Avatar
    Google AdSense Advertisement
  3. jassyo06
    jassyo06 Grumpy Detailer ! Gold Supporter Audi S3 Black Edition Porsche Voodoo Blue S3 Saloon
    16,498
    33,890
    Selling the car soon so buy some microfibre applicators and some Scholl Concepts S20 or Sonax perfect both will reduces the appearance of the scratches permanently as the scratches are on the top level of the clear coat and not through to the paint/metal, just work the polish horizontally/ vertically then finally in a circular motion, buff off inspect then repeat til your satisfied with the results, both these polishes can be got in small 250ml bottles
    At the on set of polishing apply some pressure to the applicator through to the paint and gradually reduce the pressure, a couple of minutes of polishing then buff
    Reason for applying pressure at the start is because the polishes l recommend shave a layer of the clear initially then polish the clear at the end or look ebay for a cordless drill backing plate and cutting pad
    T-800, Tashfeen and q5man like this.
  4. jassyo06
    16,498
    33,890
    "clear Coat" and "clear Coat" again, must be the same Sherry ye where on last night @q5man
    q5man and T-800 like this.
  5. DotNetDude
    133
    61
    ok, thanks, I looked at the product and I can do that! One question, if I just work the product onto the area where the scratches are, will that area not appear more polished/shiny than the rest of the side of the car? Do I need to do the whole side, or try to blend it in wit ha larger area, or does it not work like that?
  6. jassyo06
    16,498
    33,890
    Play it by ear mate as they say you may well want to to do the full car once you see the results that can be achieved with these compounds even by hand
  7. DotNetDude
    133
    61
    You may be right, having read up on the product s a bit, I could see myself getting carried away a little...
    jassyo06 likes this.
  8. DotNetDude
    133
    61
    It turns out I have a friend who has a dual action machine polisher. He said I can use it if I go any buy the pads. Is that something I should consider, or shall I just stick to doing it by hand?
  9. jassyo06
    16,498
    33,890
    Yeah mate go for it got get 2 chemical guys Hex Logic Quantum polishing pads 1 green one, the other in orange but check with him what size of pads his machine uses as the backing plates on these machines come in 2 different sizes, 150mm or a 125mm, the machine will totally remove the scratches on the clear coat
    Tashfeen likes this.
  10. Tashfeen
    Tashfeen S4 - the smile per mile machine! Staff Member Moderator Team Glacier Supercharged TFSI Owners Group Team V6 VCDS Map User Team Scuba Audi S4 Audi A3 Black Edition quattro
    5,373
    11,188
    Or better call Imran @in2detailing, tell him about the DA and want you want to achieve. Mention it to him what @jassyo06 just told you above and he'll sort you out. Very helpful lad!
  11. DotNetDude
    133
    61
    Thanks. I'll find out what size it is. This is a slippery slope in one direction, before I know it my garage will be full of specialist detailing products and equipment...
    jassyo06 and q5man like this.
  12. Avatar
  13. q5man
    q5man Mythos Appreciator Team Mythos TFSI Owners Group Gold Supporter quattro Audi Q5
    3,256
    3,751
    Haha!
  14. q5man
    3,256
    3,751
    And the problem is?
