Removed stucked M10 bolt from the door
zenyagami
Member
Hello everyone, I'm retrofitting my foldable mirrors, the driver side was ok, but I'm trying the other side and i can't loose the bolt, is an M10 bolt, i tried using WD-40 and doesn't work, my screwdriver doesn't work and now the gummy from the screwdriver moves but not the screw i tried with a cordless drill (18v) not much power but it doesn't work. And the problem is that is in a complicated place. Does someone has a suggestion/tool?
8YARWY
Living in your head......Rent Free LOL
You need a socket drive ratchet on it really.
You’ll get the leverage on it then.
zenyagami
Member
Wow, thread closed this helped me a lot, thanks i did it, pulling the mirror broke the wire probably was attached to something... Anyways I'll replace it.. i wanted to sell it tho
And the screw fell in the door i can't see it ‍♂️
8YARWY
Lol I’m Not sure if the reply is a thanks
Done loads of folding mirror retro fits never had an issue with a socket / extension bar and ratchet.
Tip……get a magnetic pick up tool to retrieve the bolt.
zenyagami
Member
Yes it was a thank you haha, thank you, i have a magnetic stick with lamp.. i can't find it tho, I'll try tomorrow again, not sure where it fell.
Do you know by chance which is the model of this screw? In case i need to search in ebay ‍♂️
8YARWY
It lists 2 bolts not sure what one of them is for but one is M8 x 25 the other one has no detail on size.
zenyagami
Member
Dunno mate the parts database lists only the 2 I mentioned above.
You can get info from the other bolt if need be.
yes you are right it was m8x25, i was not sure because the "head" is m10 (make sense now) I'm not an expert but you was right, thanks a lot!!! you saved me hahaha
i wento to Audi and they was nice enough to give me one screw without "questions" so was nice. I will continue later ... I hope I will not lose it again, also I will try to get the other. Thanks a lot for your help!!
AlS3BE
The screw is most likely stuck to the magnet on the back of the speaker.
that’s what happened to me on my 8v. Spent ages looking for it.
