Relentless V3 porting?
QuestMS
Hi all
i have seen a few posts saying the relentless v3 needs a light porting, where exactly needs opening out? Collector or ports end? Lay the gasket over the ports and trim so they match?
Cheers in advance
Jay A3
#because Racecar
Did you buy yours from Sam? Ones brought from Sam are now ported I believe
QuestMS
I got mine brand new second hand from a guy local to me, I have to swap my turbo over soon so will whip the mani off at the same time and check everything before the re fit. Was it the cylinder head side that needed opening out?
BENJAMIN
Post a pic and we can tell you if it's been fettled.
QuestMS
Cheers bud, I will when it's been removed. Should be pretty obvious if the ports don't line up to gasket though
QuestMS
Cheers for the offer bud but I have a mill at work :) failing that some decent carbide burrs and careful attention with the die grinder lol
