As the thread title suggests I'm after replacing the stock interior bulbs with some decent led white ones. Can anyone recommend a decent set? Cheers!
Has anyone not had any problems with the LED sidelight bulbs from t8ups? After 6 months they corroded, started flickering on and off causing the dashboard light to come on.
With the front set mate has to be something up with your headlight unit as there shouldn't be any moisture i there to start an corrosion so would check that one first As for the rears LEDs done produce heat and use minimal power show shouldn't be melting if you have any problems mate just email him or pm him am sure he will help you out Don't point the finger before you give the person a chance to sort it out first
I did email him? Others was having the same problem with the rear number plate bulbs in there A3's...
He's normally really good when it comes to customer service etc. Get in touch and I'm sure he'll be more than happy to help.
Depending on how you want your interior to be like, I would recommend one of these https://c2.staticflickr.com/8/7045/7134392089_e871876c99_z.jpg
