Hi all,
So bit of an odd one really. Driving the car around and I’ve noticed I’m getting a little squeaking/squealing noise..... sounds very similar to something caught up in a brake pad making contact with the disc. When I pressed the brake peddle it went away.
So further investigation led me to check the discs for scoring, etc. But nothing....
So I jacked the car up and checked the rotation of the wheels and weirdly my drivers side rear has masses of movement, it looks like it’s buckled?! But when I looked closer, the disc was moving in and out the same as the wheel!
So what’s happening is the wheel and disc are moving in and out catching the caliper/pad.
Is this a sigh of the wheel bearing on its way out or have I somehow managed to bend my hub?! Which would be mad being as everything else is softer metal.
No handling issues or knocking, whinning or vibrations. Just the squeak/squeal occasionally as the disc makes contact with the caliper/pad/dust cover.
