  2. Dismiss Notice
Rear view dash cam
ld2130 Sep 26, 2020
  1. ld2130
    ld2130 Registered User
    55
    24
    So for £50 I thought I'd give one of these a go :-
    https://www.aliexpress.com/item/4000926244214.html
    After a little swearing, it all went in ok
    Took it for a spin today, caught these two bad boys on the way out of Thruxton :)
    Seems ok, not the best rez, ok to read number plates, love the stealth look
  2. Avatar
    snack-media
    Advertisement
  3. cashutt
    cashutt Registered User
    42
    13
    That camera looks good. I’m tempted to buy one. Why the swearing while fitting?
  4. Tiger-G
    Tiger-G Registered User
    137
    22
    Am I being thicker than usual here ?? :sadlike:.
    Surely, that's a front view dash cam ??
  5. jdp1962
    jdp1962 Grumpy Old Man
    9,775
    4,339
  6. ld2130
    55
    24
    Doh not great wording on my part, read view "mirror" dash cam
    > Can’t see the images.
    Argghh I tested that last night and they worked
    Tiger-G likes this.
  7. audiwaterpump
    audiwaterpump Registered User
    114
    9
    as others have said, can't see the images.
  8. ld2130
    55
    24
    OK locally uploaded images, so the rez is even worse.
    Sorry I can't find a way of including the google photo ones.
    What are people using for including high rez images?
    audiwaterpump likes this.
  9. cashutt
    42
    13
    What are your thoughts on the dashcam and fitting it? I just ordered one from the link you posted. Any tips/advice?
  10. ld2130
    55
    24
    I've never had a dash cam before so have nothing to compare it to, it seems fine.
    Fitting was just a little fiddly it wasn't helped by the fact that the metal clips on my mirror were really weak, once I'd bent them in a bit so it held on better, it went on fairly easily.
    cashutt likes this.
  11. cashutt
    42
    13
    I tried to fit this. But the automatic dimming sensor got in the way. Did you have the same problem?
  12. Avatar
    snack-media
    Advertisement
  13. ld2130
    55
    24
    No sensors got in the way, it was tight on the wiring thou
  14. cashutt
    42
    13
    Ah ok. After doing some research it’s the humidity sensor, maybe your car doesn’t have it. I just shoved it in loose. Not an ideal situation but works.
    I’m very impressed with the dashcam though, it was quick and easy to fit, just plus right in, easy setup, good quality for £60.
