Rear DRL question
Boj27
Active Member
activated rear drl's today when in the "0" position on the switch. All works fine. When in the 0 position though, my dash lights aren't on. Should they be? If not, can anyone enlighten me to what the coding would be to turn these on in the 0 position only as well as auto?
Thanks! Fingers pointing at you DJ Alix :D:D!!
Rob2k68
Well-Known Member
Pretty sure mine behaves the same way.
pburv
@DJAlix .......:friends:
DJAlix
VAG Car Coding™ Limited
Site Sponsor
Gold Supporter
VAG Can Professional
ODIS (Offboard Diagnostic System)
Sounds normal to me. The only lights that should be on when in switch position 0 are:
  • PFL = Front Daylight Running Lights
  • FL = Front and rear Daylight Running Lights
Same goes for the Auto position during daylight.
edit: should have said that the above would be Euro spec vehicles.
Boj27
Active Member
Any chance you have the coding to turn interior lights on when in the 0 position? :) (dash, AC lights etc)
DJAlix
Site Sponsor
Gold Supporter
Only way to do this is to adjust the cars dimming profiles or "Innenbeleuchtung" adaptation channels, all 328 of them. May the force be with you!
