Rear centre heater and driverside foot heater cold
ACE5K
West Yorkshire
Hi all. The car is an Audi A4 2013 b8.5 2.0tdi the issue i am having is basically all my heaters are working fine. Apart from the rear centre console and under the drivers seat which are cold. The vent under the passenger seat is nice and warm. Could anybody advise where i should start to look or what could be the problem. Thanks In Advance for any help.
Suspect if you have heat elsewhere, then this is likely to be the motorised vents. Scan the car with VCDS and see what faults come up. Once you have a fault code you can search the forum, but likely to be a dismantle to access.
Reactions: ACE5K
Il get it scanned and report back. Thanks
