  2. Dismiss Notice
Rear caliper carrier bolt replacement.
Fatbloke Sep 6, 2020
  1. Fatbloke
    Fatbloke Registered User
    414
    135
    43
    Hi All
    When I get round to fitting my B12 kit soon, I am replacing the front (upgrade to 312mm) and rear disks and pads. What I would like to do is replace the rear triple square caliper carrier bolts with equivalent size/strength standard or allen bolts.
    Is there a suitable replacement bolt available?
  2. Avatar
    snack-media
    Advertisement
  3. pburv
    pburv Registered User
    7,011
    13,742
    Here is a company we use at work..
    https://www.gwr-fasteners.co.uk/
    What I would suggest is you use the appropriate grade of bolt..I'm guessing 'high tensile' ?
    Find out the exact thread size,length and type ie metric or imperial and then look for high tensile type which is usually marked or labelled 'S'
    This article explains the differences...
    Fatbloke likes this.
  4. Bigjase88
    Bigjase88 Registered User
    279
    97
    4.8 is normal bolt
    8.8 is high tensile
    10.9 is even higher tensile
    12.9 is even higher again.
    the problem with high tensile bolts is they can shatter quite easy. Drop a 12.9 and i have seen them break
    Fatbloke and pburv like this.
  5. pburv
    7,011
    13,742
    Not sure what happened with my link on this post??
    But this is what I meant to post up...
    https://www.workshopwarehouse.co.uk... type of grade,the structural grade for bolts.
    As @Bigjase88 has posted above you should be looking for 8.8 (S) grade of bolt.
  6. Fatbloke
    414
    135
    43
    Looks like (if these are correct for the 8v tdi) the bolts are 10.9, M12, 1.5 pitch and 65mm from the bottom of the head.
    https://www.autodoc.co.uk/febi-bilstein/9799886
    I found 60mm or 70mm mostly but the only 65mm ones I saw were 12.9 tensile strength.
    I will have another look. There must be something to ditch the triple square.
    Thanks for the info guys. Its very helpful.
    pburv likes this.
  7. Bigjase88
    279
    97
    Yeah 10.9 sounds about right
    pburv and Fatbloke like this.
  8. AlS3BE
    AlS3BE Registered User
    3,419
    2,037
    Just out of curiosity, why?
    Audi has tested the original bolts and they hold up with the braking systems so why change it? I know it’s only a bolt but it’s part of a tried and tested safety system and you you don't want to put a potentially sub standard bolt in place. Don’t think they are that expensive from Audi either.
  9. Fatbloke
    414
    135
    43
    Because triple square is a pain in the rectum , especially with limited access to hold the tool straight, apply pressure to hold it in and turn it. An Allen set screw of the same strength is much easier to deal with.
  10. AlS3BE
    3,419
    2,037
    I’m just playing devils advocate but regardless of the end of the bolt, triple square or hex, the space and other restrictions for tools is still gonna be the same. Just using a different end/socket. a new tool is possibly cheaper/safer than New bolts of unknown origins. I always like having new tools though even though I might only use them once :wink:
    Not had issues with triple squares before but I’ve not fitted brakes for years as managed to get rid of cars before I needed brakes. Saying that I’m planning on keeping my s3 so will let you know if it becomes a pain in the near future.
