Rear Brake Torque settings - Audi A4 2009 2.0 Tdi
audiwaterpump
Hello
Does anyone know the torque settings for the rear brakes?
rum4mo
I hesitated in giving you an answer, but now I've checked the torque for my B8 S4 and my wife's 6C Polo and in both cases the answer is 35Nm for the calliper to carrier torque.
spartacus68
Does anyone know the torque settings for the caliper bracket bolts?
Apparently 100Nm + 90 degrees. Meant to replace the bolts. Going with desertstorm's response on the front (which is main braking and crazy 196Nm), I've never replaced the bolts before, or used a torque wrench. They are triple squares, so wire brush head, spray Plus Gas penetrating release, then hammer triple square bit in to fully seat it. Now you can lever it off with extension bar. I don't use power tools.
