The Doctor
- Joined
- Jul 25, 2009
- Messages
- 1,390
- Reaction score
- 190
- Points
- 63
- Location
- Notts
- Website
- www.wbmcc.com
Right then, seeing as spring is almost here & I've nearly finished fitting the new kitchen (at last), I am gearing up to fit my new suspension set-up.
I shall be replacing the rear trailing arm bushes & inner arm bushes (upper & lower) with either Powerflex or SuperPro equivalents, aswell as a MkIV R32 rear ARB, Bilstein B8 shocks, H&R lowering springs and Forge adjustable tie-bars.
My question is regarding the rear arm outer bushes/joints. I'm planning to replace them with new OEM parts while I'm at it, but are these straightforward to remove & re-fit or would you advise getting these done professionally?
All advice & suggestions welcome!
