Rear ARB sizes
Jimmy TDI
Pro Tinkerer
Manchester
Morning all, just a quick question here.
Is the S4 RARB the same thickness as the RS4 RARB?
Jim
RS4 is the largest rear ARB and a highly recommended upgrade
std size is 16mm
s4 is 20mm
rs4 is 22mm
changing the rear anti roll bar will make the car understeer less but a negative effect is you will lose grip on the exit of a corner
this gives the impression the car will change direction quicker
also changing the anti roll bar on a 2wd car has a different effect than it does on a 4wd car
2mm is quite a lot of difference, so I'll just hang on for an RS4 one to pop up.
Cheers Jim
£160 is the latest price I have for the parts someone got from TPS, but I can't use TPS so it will probably be a bit more from Audi.
An S4 one popped up locally for £50 which is why I asked the question.
Blimey they have gone up in price. I recall paying £56 for mine about 16 months ago.....about £70 overall with the bigger brackets and bushes
This is what I paid last September for one from Stoke audi
1 x RS4 Rear Sway Bar (Part #8E0511409AL) £93.68
2 x RS4 Rear Sway Bar Bushings (Part #8E0511327D) £6.10
2 x Bushing Brackets (Part #8E0511439) £6.86
4 x Bolts for Brackets (Part #N10127707) £3.35
2 x Bolts for ARB links (Part #N10528103) £0.97
2 x Anti Roll Bar Links £52.32
It is well worth it and I wish I have done it sooner. You don't have to change the ARB links but i did at same time.
I already have new drop links that I bought when replacing all my control arms, and suspension.
I was under the impression that the bushing brackets are all the same size, you just need to change the bushes?
and the metal bracket to accommodate the large bush and bar
I'd recommend changing everything otherwise its not a compete job, bush brackets included as they are needed for the larger bushes, also the drop links as they are bushed and would be worn from the original installation.
I can't believe how much the prices have all gone up from TPS/Audi. Just checked my receipt from last year and all in including everything it was £98.72.
I can only assume Audi/TPS trend the demand and price accordingly.
Still worth it, every B6 S4 should have this upgrade. Obviously pointless on a B7, so even Audi thought is was a must have upgrade.
Wow! That has shot up, I priced from TPS last month and it was in the region of £120incl. (just under iirc) for RS4 ARB, bushes and brackets.
14
10
667
