Re map questions
Ryan s3 Mar 8, 2018
  1. Ryan s3
    Ryan s3 Member
    167
    19
    I have a de cat pipe on my exhaust system and gives the car a nice tone.
    Not too loud either, only issue is that the EML light comes on because of this.
    Cat bank 1 from memory.
    Stays off for a week or so them flags up the same issue again.
    I asked a local tuning company about having it mapped out and he quoted £150
    And has said he can get a safe 280 bhp.
    My car is standard other thsn the de cat and although i would love the extra power i want it to also be reliable and certanly could do with out any more bother.
    Bam s3 with a recent new used engine on 79 k approx.
    I was really only intersted in removing the EML light as it bugs the hell out of me but the extra BHP is very interesting.
    Has any body got any advice ??
    Thanks in advance !!
  2. Avatar
    Google AdSense Advertisement
  3. S3 Hilife
    S3 Hilife It's an addiction Team Dolphin Grey VCDS Map User Gold Supporter Audi S3 quattro
    883
    509
    93
    Anyone who tells you they can get you a safe 280bhp without the right supporting mods should be avoided imho, not only this you have to consider engine health which will play a major factor when tuning irrelevant of mileage so you can’t guarantee a figure, it makes what it makes
    If you’re looking at stage 2 power levels you will need as a minimum a decent flowing FMIC, 80mm TIP and filter, good healthy fuel pump, 3” DP/de-cat and possibly 550cc injectors
    Your post cat lambda can be coded out when mapping but you can also add a spacer to fool it but typically the EML usually pops up occasionally still
    Tj 0785 likes this.
  4. hydro s3
    hydro s3 S3 amk Team Ming Blue Audi S3
    632
    153
    43
    If all that was put on what rough figures do you think?
    Also would the torque not be on the edge of rod failure?
  5. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User Audi A4 Audi Avant Owner Group quattro TDi
    6,429
    3,027
    275-280 bhp is as much as you can reasonably expect from the above mods. I have the mods above on my TT, I have standard injectors with a 4 bar FPR and it made 275 bhp and 300Lb /ft . This was on an accurate dyno.
    To code out the post cat sensor is a 15 minute job if that. Find a decent tuner who knows what he is talking about and isn't going to rip you off.
  6. Stuart B
    Stuart B Well-Known Member
    2,586
    520
    if you want to code out the EML, buy an MPPS lead from ebay for £10 and download you map, use tuner-pro and the free tuner-pro checksum plugin switch off the post cat sensor and put your map back on. once you have all your other airflow mods on, up the load and timing by 10% and add some fuel with the lamfa settings. and start street racing
    Misikee likes this.
  7. badger5
    9,759
    2,143
    your local tuning company likes spinning you a line re power...
    what else will they be embellishing is what you should ask yourself
    Tomsy likes this.
  8. Ryan s3
    Ryan s3 Member
    167
    19
    Ouch, i might put my cat back on......
  9. Pasteurised
    Pasteurised Active Member
    285
    39
  10. Fordy51
    Fordy51 New Member
    Your location?
    I’m Cambridgeshire based more towards Peterborough tho, as long as it’s not APR’d or Revo then it’s a simple task to turn off all Cat functions and DTC.
    Price wouldn’t be much at all.
    Stuart B likes this.
  11. mango007
    mango007 New Member
    9
    Hi there....
    Buy mpps v13. It is really cheap. Download your sw from the car ( if download failed then pull out the dashboard fuse from the fuse box ) and send it to me! Please make a screenshot when you make it to see your HW and SW number! I've a couple of S3 decat+remap sw with 100% positiv customer feedback! My s3 is running on 255hp at the moment with decat pipe and a nice remap, but the project isn't finished yet :) )
  12. Avatar
  13. vanilla_ice
    vanilla_ice Active Member
    733
    Is it as simple as it sounds? Is the post cat sensor clearly labelled etc?
    I gather it is advisable to have car connected to battery charger while downloading/uploading the maps. Any other best practices worth mentioning?
    Thanks in advance.
  14. Stuart B
    2,586
    520
    Start by buying the lead from eBay installing the software in your laptop and reading the map onto the laptop. My original map i tried to read from an eBay purchased stage 2 mapped ECU was not 1024kb which meant it was encrypted (it was 308kb) because I spent hours trying different downloads i trashed my battery.
    But even that was simply overwritten with a BAM map. The immobiliser is not related to the map.
    You're not really supposed to talk about mapping on this forum but yes simple to do, I will gladly give you some advice in downloading the tuner pro checksum plug-in which is the most important thing to do otherwise you end up by either gaming having to disconnect battery for a couple of hours or putting ECU into "boot mode"
    There is a forum nefiousmoto.. which has a lot of knowledge but it's a little bit of a clique sometimes with vague advise.
    There is always risks involved with this type of thing, as a novice I managed it all and thoroughly enjoyed it.
    But as suggested start with the lead and software to read / write the ECU (it doesn't have to be an MPPS lead there are other leads and applications but that one I got to work) - then download the free tuner pro software and tuner pro checksum plug in and BAM map metadata xdf file to look at your BIN files. I could maybe PM you some screen shots of tuner pro to make sure we stay inline with ASN forum rules.
  15. mango007
    mango007 New Member
    9
    Yes. Charger your battery but it is under upload. If your battery is in good condition then doesn't need to charge under the reading procedure! My s3 is also has BAM engine. If your ecu same like mine then I give you my remapped file for free! If not then I'll speak with my tuner and you will get a proper safe file customised to your car
  16. badger5
    9,759
    2,143
    by managed it all you mean bricked your ecu a few times too...........
  17. mango007
    mango007 New Member
    9
    Made about 150 ecu and neve bricked 1
    Reading procedure can not bricks ecu! Especially via obd!
  18. badger5
    9,759
    2,143
    was'nt talking to you
    writing can brick.. as you know full well.
  19. Stuart B
    2,586
    520
    yeah I bricked the first time I changed a file as I didn't download the free tunerpro checksum plug-in and when I bought all the stuff to use boot mode and bench flash it was already re-accessible as disconnected for a while - hence the comment regarding risks. I didn't change anything difficult like timing, injector cycles, PID etc, most people simply copy the TTQS BFV Map as a Stage 1 to give around ~240BHP
    what's most annoying about the checksum is it will work the first time the car is started - so now I start the car then switch off and start the car again so I am not stuck somewhere else.
  20. IanPG
    IanPG Well-Known Member Silver Supporter Team Nogaro Blue Audi S3
    1,510
    632
    I always keep the checksum file marked with a capital "C" at the start of the filename
    and i check my checksummed file and save it in a separate folder to the files i play with.... we've all done it
    LOL
  21. vanilla_ice
    733
    Sorry, I don't understand this. Please could you elaborate?
  22. Stuart B
    2,586
    520
    The most important part of making your own changes to a map for these cars is that a checksum is generated as part of the file, if you change a 1 to a 0 the checksum will be different, so it needs to be regenerated using a tool or utility.
    If you write a file to the ECU with an invalid check sum, it will start and run perfectly well but if the checksum is incorrect the ECU won't work afterwards, as it only validates the checksum after the engine has started. So you cannot access the ECU until it has been disconnected from the battery for a while (couple of hours) or put into "boot mode" after being removed from the car and connected to a power supply.
    but... Tuner pro supports plug-ins for the checksum calculator and you can use it for free for personal use. Which means everytime you save a file it calculates the checksum automatically.
    The CRC on a file is essentially the checksum, it's a way of validating the file is correct to avoid dodgy corrupted ECU files setting the load to 250% or timing crazy.
    There are dangers in changing anything but the BAM xdf files are pretty good and as a novice you can just change relatively safe settings. Apply the plugin maybe use the nefmoto checksum test utility as an extra check etc.
    Exciting stuff all done at your own risk obviously.
    IanPG likes this.
  23. Ryan s3
    Ryan s3 Member
    167
    19
  24. Ryan s3
    Ryan s3 Member
    167
    19
    Could somebody clarify that the fault above is due to not having a Cat and in need of being mapped out ?
  25. Ryan s3
    Ryan s3 Member
    167
    19
  26. Ryan s3
    Ryan s3 Member
    167
    19
    And this little adapter goes in after the cat.
    2nd sensor etc
  27. desertstorm
    6,429
    3,027
    Yes that fault will be due to the fact you have no cat and a spacer will trick the ECU into thinking the cat is still there.
  28. Ryan s3
    Ryan s3 Member
    167
    19
    Sorry to be dumb, but it goes in AFTER the cat - 2nd sensor ?
  29. Ryan s3
    Ryan s3 Member
    167
    19
    Also thanks for all the advice. I looked at downloading the free maps but i could not get my head round it
  30. desertstorm
    6,429
    3,027
    Yes after the cat.The ECU measures how well the cat is working by looking at differences in the signal between the first and second sensor.
    Obviously with just a straight pipe the difference between the first and second sensors signals is minimal. By spacing the sensor it produces a slightly different signal to the first one.
  31. Ryan s3
    Ryan s3 Member
    167
    19
  32. Stuart B
    2,586
    520
    Why would you download a free map? You already have a free map on your ECU. If you are considering flashing your own ECU then at least know exactly what you are putting on the car.
    I got p420 when my car still had a sports cat and was plugged in, it happens if a time threshold passes without a good reading compared to the rest of the car status. So the spacer may not help.
  33. Avatar
  34. Fordy51
    Fordy51 New Member
    Send email over with current file and when I find time, I’ll turn off all the cat related systems and not just the fault code.
  35. IanPG
    1,510
    632
    Code it out
    Search in the s4 wiki this term
    ESKONF
    Then you need to find that address in your file edit what you need to edit. The info it all there.
    Have you pulled your .BIN yet?
  36. Ryan s3
    Ryan s3 Member
    167
    19
    Thank you very much but i am completely lost.
    I have been doing research on peoples comments but really cant get my brain round it all.
  37. hydro s3
    632
    153
    43
    If you can't get your head round it it might be better to leave it for a tuner to code out incase you do something wrong and you could be worse of.
  38. Stuart B
    2,586
    520
    as hydro has commented if you dont have the confidence to actually try (not only read comments to understand) you may be better off paying someone.
    enough people have said invest in an MPPS lead and try and only read you own map to make sure it creates a 1024KB file - to learn that tool.
    then get tunerpro and the tunerpro checksum plugin and download and download a BAM XDF and start looking and comparing all the settings.
    as an example today I updated my stock BAM map to have only a tiny bit more load and sympathetic AFR - whilst trying to confirm the replacement N75 has resolved my turbo stall/stutter etc
    all you want to do is set these to 0
    You shouldn't try and do this all at once whilst learning practice Identifying ECU and Reading ECU to make sure it works correctly. then make sure you back - up this important map, you should only ever make a copy of it to practice or play around.
    As suggested it can be dangerous if you change the wrong thing or use the wrong values, so it has to be at your own risk - or you pay someone to take the risk they will have insurance for any mistakes.
    Best of Luck
    Edit:
    Ryan you have changed the Turbo in your S3, this little job is well within your capabilities. you dont need to write anything to the ECU to start with and if you like you could share your amendments. it's not a 5 minute job to learn these but there is very little risk in doing the first step of reading the BIN and viewing it / comparing with other random BAM/AMK maps to find and start to understand some basics.
    IanPG and hydro s3 like this.
  39. IanPG
    1,510
    632
    @Stuart B you've made it a helluvalot easier than trawling through the code speak on nef
    hahahaha
    Good job ;)
  40. Stuart B
    2,586
    520
    the best thing I had seen on nef was when someone corrected my Y Axis description with something else only then be corrected to it being some other thing by the next person - like a three step PWNED - just need nynet to say you are all wrong
  41. vanilla_ice
    733
    Does this cause any issues with fuel trims?
  42. Stuart B
    2,586
    520
    That's the instructions on how to map out the rear O2 sensor, I don't know the answers to where else it might impact the set up. I don't recall the instructions including "... and remember to....."
    hydro s3 likes this.
