  2. Dismiss Notice
Re map advice please
Rachel Deller Oct 26, 2019
  1. Rachel Deller
    Rachel Deller Registered User
    Hi all
    hope this is the correct place to ask. I’ve been looking and can’t find anything specific to my car
    It’s a 2002 1:9 TDI Quattro 1:30 engine. Hope that’s specific enough sorry if not lol
    I’m looking at getting a re map. Have cleaned the EGR. Clutch is good. Car seems spot on but I’ve been told a re map on these engines can cause issues. As in driving it certain ways?
    it’s a bit of a minefield tbh so much to read and take in my heads frazzled.
    Any advice from those with the same would be greatly appreciated
  2. Avatar
    snack-media
    Advertisement
  3. Gazwould
    Gazwould Registered User
    7,628
    3,077
    Your AVF will happily remap to 180bhp but it's all about the torque..
    How smoothly it comes in and how much .
    300 ftlb is about the limit for longevity on a used clutch with most 165 bhp maps around 288 ftlb .
    However there are a few 175 bhp 265+ftlb maps about that won't stress the clutch at all.
    Excellent having a 2002 as you can simply disable the egr too .
  4. Rachel Deller
    thank you so it’s just about chatting to whoever does the re map really then isn’t it.
    hear horror stories lol made me worry a bit. I’ve waited so long to get my car don’t want to balls it up for extra speed lol it’s lovely just no ooomf
    sandis pēlmanis likes this.
  5. Gazwould
    7,628
    3,077
    The 5 speed AWX is where torque is even more crucial because of its smaller 228mm clutch Vs 240mm 6 SPEED in the AVF .
  6. Rachel Deller
    Ahh I see! Yes this is 6 speed
    Beginning to get it a little more now lol
  7. Gazwould
    7,628
    3,077
    Pull the vac line to the egr metal actuator hat , plug the vac line with a small bolt and hey presto you have egr disable and your B6 now only breathes clean cold filtered air .
  8. SemedoB6
    SemedoB6 Black and white a4
    506
    143
    43
    If you have a 1.9 you can map it without worrying.
    And like it was said. Being a 2002 you can simply remove egr.
    I removed it on mine when I had the A4.
    Just mine was the 5 speed awx.
    Sent from my SM-N960F using Tapatalk
  9. pauldazzle
    pauldazzle Registered User
    1,338
    119
    Remapped most of my many VAG cars in the past, including my A4 PD130 & Revo Technik was my favourite. As long as your Clutch is good you shouldn't have any problems.
  10. sandis pēlmanis
    sandis pēlmanis Registered User
    57
    So it's means that I can get from my AVF 6 speed 180hp with only remap? Original turbo and injectors. (my egr is deleted long time ago )
    Sent from my FIG-LX1 using Tapatalk
  11. Gazwould
    7,628
    3,077
    Yes , a decat will help to get there too .
  12. Avatar
    snack-media
    Advertisement
  13. sandis pēlmanis
    57
    Where I can find to buy Remapped engine CPU I look in ebay couldn't find more then 165HP remap ecu with an imo off
  14. sandis pēlmanis
    57
    Where I can buy the Remapped engine ECU with 175....180hp and imo off.....? Link please......
  15. Rachel Deller
  16. Monzta
    Monzta Registered User
    128
    10
    Can this be done on a 2004 AVF too?
  17. sandis pēlmanis
    57
    Rachel Deller likes this.
  18. Gazwould
    7,628
    3,077
    2004 AVF yes but it will throw a eml as after 2003 the egr vac signal is monitored by the ecu .
    Only trouble with egr delete kits is you loose the anti shudder valve, most report a smooth shutdown but there is a risk of not being able to stop diesel run away .
  19. Gazwould
    7,628
    3,077
    The wrong kit above anyway as 51mm , AVF , AWX etc are 57mm .
  20. sandis pēlmanis
    57
  21. sandis pēlmanis
    57
  22. Jacko1
    Jacko1 Registered User
    53
    13
    I have the same model as you, mine had a stage 1 remap by superchips @ 110K , the car now sits at 230K and im still running the same original clutch & DMF - post remap performance and drive ability are like night and day - I thoroughly recommend Superchips , my next car will also be going to them.
    https://www.superchips.co.uk/search?make=2&fueltype=2&model=22&variant=49
  23. Monzta
    128
    10
    Thanks for the advice gents.
  24. Rachel Deller
    Thank you! I know a bloke who owns a company who remaps so I’ll go there but thank you! Just wanted actual peoples advice who’ve owned this one and had it done or not if they felt they shouldn’t lol
  25. Gazwould
    7,628
    3,077
    What company ?
  26. Rachel Deller
    It’s a local one to where I live. He’s re mapped my old A4 and the Skoda VRS so I trust him lol having it done tomorrow. Tbh he would of said if it shouldn’t be done. But just wanted to check with people who’ve got these cars and had it done
  27. Nick2020
    Nick2020 Registered User
    Good evening , software remap Revo stage 1 goes up untill 180 BHp, without any changes. Tested and sounds amazing. Avf engine-6 speeds gearbox.
  28. Jacko1
    53
    13
    Does this throw any warning lights on the dash? do you find the car runs better?
  29. Gazwould
    7,628
    3,077
    What year and plate is yours ?
    Yes , low rpm turbo spool improves as some exhaust gasses are no longer being diverted through the egr .
    Due to improved efficiency , a few mpg better too .
  30. Jacko1
    53
    13
    Hi, Its a 2001 AWX engine code. I see there are kits with blanking plates available to remove the pipe that goes from the bottom of the EGR to the turbo - is it necessary or is just removing and plugging the pipe that comes off the top of the EGR going to effectively produce the same result?
  31. Gazwould
    7,628
    3,077
    Yes .
    You can always put a 1.5mm thick slip in blank in the bottom of the pipe .
  32. Ralphthemouth
    Ralphthemouth Registered User
    201
    54
    I remapped my 1.9 awx 5 speed 130, to 175bhp using an MPPS device and a map from the blacksmoke website. It took two mins, and cost me £45.
    70k miles later its still perfect. Why spend £200+ on a fancy custom map? Its only a 1.9 diesel.
