hey, i am trying to fit some 6pot brembo's and i need either a 350x32 or 330x32mm disc, both of these come on the cayenne but can i re-drill the pcd from 5x112 to 5x100? and anyone know a good place to go? cheers tom
cayenne isnt 5x112 its 5x130. You probably can redrill them, as the disk is located by the centre spigot and clamped between the wheel and hub. I had redrilled disks on an old astra (5x110 to 4x100) and it was fine. The bigger issue will be the disk offset if you plan to use readily available brackets?
thanks dude i have the brackets already and they can be run with mk4 r32 discs or 350x32mm brakes from the cayenne according to the guy i got them from, does this sound right? and it seems i can get better discs for my money in with the cayenne discs and then re-drilling depending on prices. cheers tom
