  2. Dismiss Notice
Rattling backend on a 58 plate A3 TDI.
Dave205 Jan 16, 2020
  1. Dave205
    Dave205 New Member
    Hi guys looking for anyone with ideas for a rattling rear end on a 58 plate A3. I've had it checked and was told everything is fine so really don't understand why there is so much noise.
  2. Avatar
    snack-media
    Advertisement
  3. John Lang
    John Lang Member
    58
    9
    Check for broken springs first.
  4. Nessy
    Nessy VW + Audi mad
    1,354
    190
    Also check that the plastic guard things that cover the rear suspension arms aren’t loose....if they are they rattle away over every bump etc.
    A couple of plastic cable ties deftly positioned is pretty effective at silencing them.
  5. Nessy
    Nessy VW + Audi mad
    1,354
    190
    Also this, I had a very metallic rattle that initially I couldn’t trace, until I peered/felt inside the rear lower suspension arm and found a chunk of the top of the rear spring that had broken off and fallen in there!
    The pressed steel arm has a U shape and is a perfect receptacle for catching bits of broken springs!
  6. NHN
    31,119
    2,162
    3dr, 5dr?
  7. SootySport
    SootySport Well-Known Member Team Silver
    4,046
    1,080
    That pressed steel arm also collects water( seems like it was fitted upside down, surely should not be designed like that) I noticed mine had lots of surface rust when I changed my rear springs, painted it with Waxoyl to stop it corroding.
    As for rattles, heatshields and plasticovers can come loose. If a Quattro check the metal ring on the end of the prop shaft, it can come loose.
  8. Nessy
    Nessy VW + Audi mad
    1,354
    190
    Good idea.
