  2. Dismiss Notice
Rain Sensor
pburv Jan 18, 2016
  1. pburv
    pburv Registered User
    7,005
    13,735
    Hi All.
    I am in the process of retro fitting Auto Dim rear view mirror .
    Whilst taking the back off the existing mirror I noticed that there are wires already connected to a rain sensor on the windscreen..
    The question I am asking is it just a matter of coding the car via vcds to activate auto wipers??
    My car is not fitted with auto wipers or lights..
    Cheers Paul :chuncky:
  2. Avatar
    snack-media
    Advertisement
  3. Rob2k68
    Rob2k68 Well-Known Member VCDS Map User
    7,357
    11,203
    Hmm good result that the sensors there !! - you'll need the light switch and wiper stalk too I would have thought to get both working best person to help is @DJAlix or @NHN
    pburv likes this.
  4. pburv
    7,005
    13,735
    Cheers Rob.
    I was more interested in getting the Auto mirror fitted Just thought coding the car for Auto wipers was a simple and cheap mod considering I thought that the sensor was already there..
    I wonder if all A3/S3 models have the sensors fitted from factory?
  5. DJAlix
    DJAlix VAG Car Coding™ Limited Site Sponsor Gold Supporter VCDS Map User VAG Can Professional ODIS (Offboard Diagnostic System)
    6,703
    5,125
    Are you sure what you have is a rain sensor and not just a humidity sensor, which is fitted as standard with Auto Climate Control? Rain sensors normally only come fitted it you have factory Auto Lights / Wipers. Best way to tell:
    • Load up VCDS
    • Run an Auto Scan and see if "RLFS" shows up under your 09 Cent Elect details.
    or
    • Load up VCDS.
    • Select 09 Cent Elect
    • Select Long Coding
    • From the Drop Down box in the pop up see if you can select RLFS
    RLFS = Rain Light and Humidity Sensor (8U0-955-559-B)
    No stalk needed for Auto Wipers & Lights, just a new light switch with an Auto position.
    Rob2k68 and pburv like this.
  6. pburv
    7,005
    13,735
    Thanks for the reply.
    Unfortunately I don't have access to vcds As to whether it is a humidity sensor or rain sensor I wouldn't have a clue..
    This is a picture of the back of the sensor....
    Sorry about the poor picture quality...
  7. DJAlix
    6,703
    5,125
    Pictures are not showing up :(
  8. pburv
    7,005
    13,735
    Oh! Not sure why that is..They show up on my computer??
    Any ideas as to why??
    So Sorry:concern:
  9. DJAlix
    6,703
    5,125
    No worries. This is a photo of a Humidity Sensor. You might be able to make out some part / reference numbers from yours to match up to this one. DO NOT remove yours in order to see. Although held in with a metal clip it's also secured by a gel pad which secures it against the windscreen, which is single use only and will 10000000000% need to be replaced if damaged.
    pburv likes this.
  10. pburv
    7,005
    13,735
    OOPs I did remove it today??
    How will I know if it's damaged??:sadlike:
  11. DJAlix
    6,703
    5,125
    Did you see a circle of gel stuck to the windscreen when you did, and if so was it damaged in anyway?
    To be honest you would prolly be ok if you only have a humidity sensor as the "sensor" part is on the lower section and not the main body. If fitting a rain sensor then you will need a new one as there needs to be a solid and clear bond to the screen for proper operation.
    Edit: The white'ish dot on my sensor body is a reflection. Infact... I just thought of another identification method. Look at the sensor from outside your car and through the windscreen. If you can see a clear / glass LED type dot on the lower section of the circle then you have an RLFS.
  12. Avatar
    snack-media
    Advertisement
  13. pburv
    7,005
    13,735
    Cheers DJAlix.
    No I don't have the extra clear dot on the windscreen..
    Hopefully I haven't damaged anything.Thanks for clarifying what that component is.Looks like I will need to buy an extra cable from Kufatec to enable the Auto Dim mirror...:friends:
  14. DJAlix
    6,703
    5,125
    I did the same :) Just waiting on weather to get a little better before installing.
  15. pburv
    7,005
    13,735
    Can I be a bit cheeky and ask how are you going to wire it up??
    Could you possibly put up a wiring diagram??
    Oh! and what part number the cable is...:whistle2:
    Cheers mate...
  16. DJAlix
    6,703
    5,125
    Sure. Part Numbers in the photo :)
    To install I was gonna follow the official Audi workshop diagrams. Will post up a dropbox link later.
    pburv likes this.
  17. pburv
    7,005
    13,735
    Your a star DJAlix....
    DJAlix likes this.
  18. DJAlix
    6,703
    5,125
  19. veeeight
    veeeight I am a very pretty girl VCDS Map User
    6,842
    4,762
    Blackwhite and pburv like this.
  20. pburv
    7,005
    13,735
  21. Johrul
    Johrul Registered User
    Hey ladies and gents I really need some help please and will appreciate any thing you guys can help me with. I have a 65 plate Audi A3 saloon sline. I have the climate control sensor already installed and the dimming rear view mirror. I want to retrofit the ligh/rain sensor on my own aswell as the coding using VCDS. Please tell me which parts I will need. Rain sensor, light switch with auto option and 2 front fog light buttons . Will I need anything else a wiring loom? And gel pad?
  22. Johrul
    Also how do I wire the the new light switch is there anything extra needed for the auto switch and also how do I take the light switch out correctly.please will appreciate your help
  23. CB98
    CB98 Registered User
    27
    I don’t have auto headlights but when I go into a tunnel or it’s dark outside the lights on my dials dim down. I guess there must be a light sensor fitted. Would I be able to get auto headlights activated by simply changing the switch?
  24. DJAlix
    6,703
    5,125
    Interior ambient lighting is controlled via a sensor located within your instrument cluster. This sensor cannot be used for Auto Lights and Wipers.
